hi, am art from the philippines.i bought this compact electric pressure washer, black and decker PW 1400. ive been using it for a year using the same faucet as source of water.At present, my units engine is running well but when i turn on the faucet, it suddenly stops with no pressure at all.The engine is running well except that when i start opening the faucet to give the supply of water the engine just stop..how can i fix this. thank you
-   Ik heb ook een preobleem met de Black en Decker PW1400. Motor wil niet started na een jaar niet in gbruikt te zijn. Hoe kan mij ook helpen deze te oplossen. Alvast bedankt. -   spbertrand
Mar 17, 2009
-   i have a McCulloch power mac 1300 pro number 20218992038 ineed anew hose were can i purchase one from -   johnadams200
when i press the trigger the machine operates for about 10 seconds then cuts out then starts and...
(More)
when i press the trigger the machine operates for about 10 seconds then cuts out then starts and cuts out this continues for about 15 times then it cuts out and has to be switched of before it will start again
Hi, my Karcher steam cleaner is working ok apart from the burner does not come on to supply hot...
(More)
Hi, my Karcher steam cleaner is working ok apart from the burner does not come on to supply hot water. Got ok pressure from the lance but cold only. Plenty of fuel, it was working recently and it is stored inside, any ideas please?
