Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
A
Anonymous Posted on Feb 20, 2012
Clean head epson stylus sx215 - Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
5 Related Answers
efs_perpends
efs_perpends
  • 1997 Answers
  • Posted on May 26, 2009
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sanath Kumar V
  • 684 Answers
  • Posted on May 27, 2009
SOURCE: Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Goldi Kunal
  • 187 Answers
  • Posted on Sep 30, 2010
SOURCE: How to Change ink cartridge
#1 Wait until you are out of ink. The warning light and ink-low notifications come on well before the ink cartridge is empty, and even if it runs out of ink in the middle of a print, you can replace it then and finish the print with no problem.
#2 Lift the lid of your Epson inkjet printer to expose the ink cartridge replacement button. Make sure you have plenty of light so you can see what you are doing.
#3 Press the ink cartridge replacement button. This will loosen the empty ink cartridges so they can be pulled up and out.
#4 Fill the empty cartridge at an ink-refilling location, or buy a new ink cartridge to replace the empty one.
#5 Insert the new or refilled ink cartridge into the holder with the same orientation as the previous one.
#6 Press the cartridge replacement button to charge the system and close the printer cover. Charging takes about one minute
Thanks
Anonymous
  • 7191 Answers
  • Posted on Oct 04, 2010
SOURCE: i have epson stylus sx215
You can download the installation driver and software from manufacturer's site by clicking this link
  • On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu and download the drivers and software from the ist which opens.
Hope this solves your problem. Thanks for using FixYa.
Anonymous
  • Posted on Feb 22, 2011
SOURCE: Epson Stylus SX215 the ink cartridge holder won't
its because the ink housing will only aline when the ink is empty its not like any other printer that you can line the housing up. Wait until you run out of ink then lift up the lid and the housing will be alined - its stupid system and epson dont tell you this when you buy the produc
Epson sx215 wont print pdf files
You need to clean the print heads first - if they are blocked they won't print.
Clean them several times - then try the print check.In Case You Still Having Problem Then Follow Us For On : Epson Printer Support
4helpful
Can i install my epson stylus sx215 without the disc?
Yes, you can. Get the printer driver online. Go to this website http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-SX215/Drivers-Support.
Select "Drivers and Software" and download the driver.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment in return. Have a good one!
My mum has lost the cd to install her printer....epson stylus sx215
hi. use this link http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-SX215/Drivers-Support?supportLandingPage=true and download the apropriate drivers for your opperating system
Hi where can i get a manual for a epson stylus sx215?It has no driver either.
Hi Samantha!
Epson Stylus SX215 Drivers & Manuals
Please visit the above link from Epson Official Support. Download the drivers according to the Operating System you have on you PC. Go to Manuals section for the desired User Manual etc.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
13helpful
3answers
I have a new epson SX215 and have lost the manual.I cant figure out how to replace the ink!! Help needed quickly please., Anne Cunningham
Hi Switch on the printer give a print job and open the panel the head comes to the centre and then you can remove.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
