Question about Home
How to adjust water temp on a dreamline shower column
  • 19 Answers
SOURCE: Water Temp not hot in shower
you need an allen key to remove the handle once the handle is removed than you need to turn the grey plastic temp guide counter clockwise as far as possible
Posted on Feb 02, 2009
rahnzkie_18
  • 32 Answers
SOURCE: Fluctuating water temperature in new Price-Pfister Treviso shower
hi there! there is a technical problem in concern with that for sure...try checking the handle it might be loose already. things like that do happened all the time. thanks, kindly rate.
Posted on May 02, 2009
ExHandyman
  • 86 Answers
SOURCE: I have a pioneer shower valve that has pressure problem
The way anti-scald valves work is there is a slide tube inside the faucet which requires pressure from both hot and cold or else it will cut off the flow. As for temperature adjust I do not believe there is an adjustment screw but more so there are these white plastic toothed stop rings which prevent the handle from turning 360 degrees. When your adjust the stop ring, it adjusts how much hot water is allowed to mix with the cold water. My wife likes her showers a lot hotter than I, so I gave a good allowance with the stop ring. The "adjustment screws" which you are viewing are not for adjustment of temperature, they are remote cut-off screws to stop the water entirely to change the washers in the unit if needed. SO open those all the way and leave them open. Think of them as not having to go all the way into the basement to shut off the water supply just to change a few washers.
Posted on Mar 20, 2010
Testimonial: "Thank you exHandyman.... it worked "
SOURCE: The water is too cold coming out of the Moen Adler
Turn the cold water feed down as low as possible to maintain pressure and increase the temp on the water heater.
Posted on Aug 12, 2010
Suzman
  • 642 Answers
SOURCE: Hello I have just installed a
This unit is indeed adjustable.
You'll need an adjustable wrench and philips and small flat screwdriver.
However the temperature water coming out the faucet should be the same as out the showerhead as these two are on the same pipe after the cartridge.
To adjust:
Pry off the cap on the handle. Undo the screw in the handle and remove the handle. Remove the collar below the handle with the tool provided and remove the collar.
Unscrew the backing plate and remove. Remove the plaster guard.
Remove the base nut and its retainer nut to expose the cam.
This cam can be used to adjust hot water temperature. Note its position, remove it and move clockwise of its present position to increase hot water temperature.
If youre not at the correct temp yet :
On both the hot and cold inlet pipes are stop valves that can be adjusted by screwdriver to increase/decrease water flow. Open both fully.(counter clockwise)
Posted on Nov 18, 2010
Can I adjust the hot water temp if I have a Posi-temp faucet?
should have a gearlike part under handle that can be adjusted so as to allow the handle to rotate to more hotter (left) or warmer
Dec 08, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
How can I adjust the shower knob to produce hotter water then it does now. It used to be hotter. Taking the knob off reveals a white piece of plastic with a colder to hotter temp. gauge. How can I adjust...
Should be able to adjust clockwise or counter clockwise to adjust the temp. You said that the temp used to be hotter. Check the temp setting on your water heater. Did you replace your old water heater? Hope this helps.
Mar 07, 2010 | Home
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
Feb 01, 2009 | Delta & Leland Lavatory Faucet
Home Logo
41 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
