Bush LCD26TV016HD My tv ( built in freeview) keeps losing connection, screen goes blue with the letters DTV in the corner but picture comes back a few seconds later, Very annoying as it does this every few mins! Cheers
  • 1 more comment
  • elrod5175 Dec 07, 2008
    My LG 26LX1D loses its connection for a couple seconds.This happens on several tv input settings like HDMI and Component 1.The screen will go black for 5 seconds and display the current input setting and go back to normal.This occurs like every 45 minutes.
  • messiah150 Feb 27, 2009
    i have the same problem. channel goes blue with the with channel 1 mono lettering in top left hand corner for about 5 seconds with no sound then switches back to the scart channel i've got my freeview running through. this happened a few months back and i fiddled with the scart leads and it seemed to stop. Now a couple of months on it suddenly started doing it again but happens every 40 seconds, really frustrating!
    do you think it could be the scart leads? i've only got bog standard cheapest in the shop leads?
  • messiah150 Feb 28, 2009
    just bought some more scart leads 2day and its still doin the same. i'm guessing the tvs probably had it and its not something simple like leads or setup wrong. also i called the bush helpline today and they asked me. "Have you tried turning off your tv and then turn it back on again?" like i didnt already try that! other than that i'm waiting for a call back from a bush technician to see if he can diagnose the problem
5 Suggested Answers
SOURCE: built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Posted on Dec 25, 2008
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
SOURCE: tv keeps disconnecting from digital tv, returns within 5 seconds but highly annoying! pictue goes blank and sounds goes aswell , almost like the tv has turned off only to restart itself
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
Posted on Jun 01, 2009
  • 6 Answers
SOURCE: i have a goodmans LD1940WD purchased 2007 it was
There does not seem to be a fix for this at this time and the software version may need to be updated. My set is the same...takes a long time to warm up and encode. Once its warm its perfect slow to tune but perfect with signal levels 63 to 78% the picture is stable and error free across all channels. One dead pixel in a 3 year old panel not too bad. I can be reached at sunray at shiftmail dot com
Posted on Apr 08, 2010
gregs_rockin
  • 274 Answers
SOURCE: Hi. We have an old analog TV (Sony) which has a new digibox running through it (since the switch over). Was fine, but over the last few weeks, intermittently, the screen goes black with EXT 1 in the t
Your picture tube is on the (Verge) Of going.
Posted on Oct 09, 2012
Why does my pvr keep freezing
Sorry can't help on this. Presumably you've switched off/on at mains and checked all connections secure. Would a factory reset help, see tips how to do on fixya, although not sure if you would lose library data.
Aug 19, 2014 | Bush BTU500DTR 500GB Twin Tuner Freeview...
Have just retuned digital terrestrial receiver Matsui DTR -2 for our area, how do I now record tv programmes with my Bush VCR925NSILXI? On analogue TV the recording channel was Channel 9
Recording, amazingly, has nothing to do with your TV, it only monitors the playback or recording input of your VCR or DVD recorder - the Channel 9 you mention.
They have their own tuners, indeed DVD recorders have Freeview (or DTV) tuners so no need for a separate box at all - given that your TV has a DTV tuner too and if a recent flat screen type it will.
If you can afford it, this is a good time to drop VHS and get a DVD recorder. You'll find plenty on Amazon Electronics for a start.
Your Bush VCR will be redundant the moment the analogue service goes off, they haven't made a VHS VCR with a DTV tuner.
Depending on your area this is a few months off, even for the last area to change over anyway, here in London there's just shy of nine months left.
Sep 21, 2011 | Televison & Video
Does this TV have built in Freeview ?
Yes,all tvs that are a LCD or a Plama tvs that are a flat screen tvs picture panels can recieving Free over the AIR DTV broadcasting incomming tv channels.Buy and used a Digital design tv Atena for a long and strong recieving incomming tv free signal DTV channels.
Aug 15, 2011 | Philips 26PF8946 26 in. HD-Ready LCD...
Hitachi L42VC04U cant get freeview at all. Freeviewworks fine on another tv
The easiest way to check if the fault is with the TV or the aerial is to plug the TV in where the other WORKING TV is connected to the aerial.
If it works, then you have a problem with the aerial or the aerial cable.
If not check that the TV isn't in analogue mode. Press the "DTV" button on the remote. The TV should display "DTV" in the top corner of the screen.
If you are definitely in digital mode, and freeview doesn't work when the TV is connected to the other aerial connection, then you probably have a faulty TV.
Is the TV new or was it working OK previously?
Please rate my solution if you find this helpful. Thanks.
Oct 14, 2010 | Televison & Video
My freeview needs retuned
If it is built in. Do the following.
Press the button on your tv remote that says TV/DTV.
Make sure it says DTV on the screen normally at the top corner of the screen.
Now with the Tv remote press the menu button. you should now see a menu appear go down to Auto Tune / Auto Store and press select or enter. T
his should now start searching through for you Freeview Channels. Dont be alarmed if you dont see many channel appear at the beginning of the scan as it normally goes past 75 % before they start filtering through.
If your box is a standalone then Just use the Freeview box remote and then press the menu button. go down to Install. this would then prompt if you would like to do a full search or add channels. I would do full search this will Delete all the channels previously installed and search from scratch.
I hope this sort out your Freeview
Little Dish Fitter
Sep 22, 2009 | Samsung Televison & Video
Does the Bush LT26M1CA have an analogue tuner
Hi, Your Tv does indeed have an analog tuner for UHF and VHF reception. Remember you need to have an external antenna connected to receive anything via the analog input. On your remote in the upper right hand corner is a button labeled tv/dtv that will switch back and forth between your analog and freeview digital. Good Luck, this should Fixya!
Mar 20, 2009 | Televison & Video
BUSH LCD 17TV004 picture goes off!!!
if yo know how to solder , re solder your tv, second adjust the IF transformer by using the plastic or wood stick. IF transformer is looks like a cube made of metal with an adjustment screw at the top. try to adjust it and observe what happen.
Oct 16, 2008 | Bush 5693D 24" TV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Electro Med Services...
