Question about Intel D845GLLY Motherboard
NO Display, POST or speaker beep
I have been using D845GLLY with 1.7 Mhtz, 512 RAM for few years but for the last some days, whenever I try to start it, the LED on Mobo starts lit, cpu fan also starts but no POST or display at all and no speaker beep!, strange thing is that when I keep trying to start it for 2-3 days it suddenly starts working normally! and if you start it or shut and restart many times it works all fine and normally, but when try to start in next day same thing happens NO Display etc. etc. and on keep trying in 2-3 days starts again!
I have re-seted the bios many many times, changed the RAMS, re-inserted the processor, replaced the power supply and switches but still the same result sometimes it starts and many times not, there is nothing loose or broken on board. I have also tried with minimum attachments to board, means no LAN cards or NO drives etc
When it is working it is 100% perfact and when not working then the output is zero!
Could you please help to resolve this strange problem!
Many thanks and kind regards,
Alam
  • 1 more comment
  • phptrack Oct 27, 2008
    One more thing that I have also tried to check this with new monitor as well!
  • Targos Jan 31, 2009
    I have a similar problem, the difference is that my pc never start again... I tried cleaning like you said, I tried with a different ram and nothing...Any idea???
  • kendeacon Mar 31, 2009
    power supply works...board light glows green... but nothing when i press button. . any way to test board ? --- processor ? could bad memory prevent boot--no beep at all?
  • 152 Answers
Clean your cpu and put new heatsink compount
clean ram contact using student eraser
if you have postcard so you can judge problem
Posted on Jan 20, 2009
Dell latitude windows 7 how to find out what the beep means
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains
1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
Hope this helps
Nov 27, 2012 | Dell Latitude E6520 PC Notebook
I have not get display due to mother board no access the RAM. and i have check the mother board without install RAM and i did not get any beep/sound plz tell me what is the problem and how i can solved...
This motherboard has an on-board video card and it uses shared RAM. The video uses part of the main RAM and if there is no RAM modules installed then you will not get any display or POST beep codes.
Jul 14, 2011 | Intel Desktop Board D845GLLY Motherboard
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
I have Intel Desktop D845GLLY motherboard, recently it has no display and when power is on it gives three beep. I have a intel board that was running find until i upgraded memory and changed the dvd...
The three beeps tells you that something inside the system is not properly installed. Check all hardware installations and position properly all hardware not properly installed. If nothing is improperly installed, try cleaning the RAM with a piece of clean cloth and install properly.
Feb 20, 2011 | Intel Computers & Internet
For D845GLLY ,i tried with 512MB SDRAM(Duble side),had booting pb
make sure the ram is working fine just connect to other working system and check the ram are ok .but i m sure this is motherboard problem kindly show it service center or change the motherboard.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | Intel D845GLLY Motherboard
Problems with 3 brand new PC 133 512 MB RAM in Netvista 6794
That last RAM probably is good. Many motherboards have problems using many different memory. All of the memory you have should be at least identical to ensure that they work. When RAM run at different speed or require a little more voltage, they will not let your motherboard boot. You can try mixing up the order you put the RAM in. Try putting the last RAM in the first slot by itself, the motherboard should boot. Then try the rest.
Also, whenever you add or change hardwares, you should clear the CMOS/BIOS settings.
Jan 06, 2010 | IBM (49P1599) Motherboard
My computer is not starting, no beeps, no lights except that the fans are working? the last time i used my computer it was working perfectly. after almost one year, when i switch my computer on, i noticed...
One of the most common failures is Power Supply. Try first, unplugging and leaving off for a few minutes before trying to start it again. Sometimes this helps, but I expect you will need to dig deeper.
Oct 20, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Problems with Foxconn 6100K8MA-RS Motherboard memory upgrade
This is an oldtime POST code memory error. Likely that ram is either installed wrong, bad RAM or the mobo doesn't like one of the memory sticks.
See http://www.computerhope.com/beep.htm.
You must count the beeps.
Mar 17, 2009 | Foxconn 6100K8MA-RS Motherboard
Intel 82845G/GL motherboard running on 256+128 (384) RAM. I want to upgrade RAM to 1 GB (2*512) but it is unable todetect and give 3 beep sound.
One or both of the new RAM modules is incompatible, defective or not inserted properly. Try one at a time also verify your board supports 1GB and the type of RAM you are using.
Feb 17, 2009 | Intel D845GLLY Motherboard
Problem upgrading RAM to Intel D845GLLY
Most likely the memory is incompatible or in the wrong configuration. Check here to see the proper configuration for this motherboard.
Jul 16, 2008 | Intel D845GLLY Motherboard
Intel D845GLLY Motherboard Logo
186 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
