Question about Hitachi DZ-MV550 DVD Camcorder
Hitachi dz-mv550a dvd door jammed
I must have loaded the dvd incorrectly. Now the door won't open. Can anyone help?
When you get to the small rectangle hole use a small flat screw driver. you'll see the lever on the door side. put you're screw driver to the front and pry it backwards and it will unlatch.just pressing on it won't do anything.
Posted on Sep 19, 2007
  • 3 Answers
This is actually straight forward. Turn the lense cover off the front. take the three screws out now exposed that howl the lense barrel on. Don't worry you can't damage anything it's just cosmetic. Slide the barrel off. Just at the back of the barrel infront of the hot shoe you will see a small hole into the top of the camera. If you use a pen or similar device you can press the release lever to open the door manually. Thast right out of teh service manual. Good luck
Posted on Aug 30, 2007
Solution #7 actually worked for me. It was jammed, I dropped it, it popped right open. Go figure.
Posted on Aug 21, 2008
It's easy. unscrew the lens from the front. remove the three or four screws holding the lens barrel cover on. underneath this you wil find a hole. using a pen tip you can lever the lock and the door will open. from the service manual.
I was never able to fix it. I am probably going to have to send it in to get fixed. I hope that you have better luck than I did!
Posted on May 31, 2007
    Welcome Back:
    Visited the website for 2 consecutive days.
Nedaly, Sorry I can't help but I now have the same problem. My grandchild was playing with the camcorder and now the door is jammed. I was wondering if you could tell me what the final fix was. Maybe it could help me get this one open. I don't want to chance forcing something and perhaps break it. 89corvette boltonites@sympatico.ca
Posted on May 30, 2007
Throw it up in the air and let it hit the ground .. if it still willnot open sell it on ebay
Posted on Feb 19, 2007
The troubleshooting section says: Symptom: Cover will not open Cause and correction: Did you disconnect the batter or AC adapter/charger during removal of disc? Reconnect the batter or AC adapter/charger and then turn the video camera on. Not sure if you've tried this but worth a shot if not. Steve
Posted on Dec 17, 2006
SOURCE:
94 VW Golf Rear cargo door won't open
you might have hit hard to close the door. open door pad n try to open the gate
May 14, 2013 | 1994 Volkswagen Golf
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
My sony progressive scan 5 dvd/cd changer door won't shut, first it wouldn't open, thej i used a small screw driver, and pried it open, then it open then won't shut?
This is a loader mechanisn fault. Mithe be eiter to a loose loding belt, or defective loading gear wheels.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
May 17, 2012 | Sony Televison & Video
Door won't open to insert dvd
The gears are jammed, the timing gear is out of sync, or a broken loading belt, or cogwheel.
Apr 19, 2012 | RCA DRC233N DVD Player
Zenith dvd/vcr model ABV341 DVD WON'T STAY IN TO PLAY...VCR WORKD FINE
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
Apr 04, 2012 | Zenith Televison & Video
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
Door won't open
Hi!!!
What you need to do is to prepare philip screw and oil.
1.) open the back cover of your dvd by unscrewing it.
2.) look for the center area specially on the door.
3.) put an oil where the door close and open.
You can also put oil to all moving parts for much better result.
4.) then try to test it if it works,
hope it helps you and rate me if it does.thank you..
Nov 25, 2011 | Televison & Video
DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Oct 08, 2006 | Sanyo DVW-6000 DVD Player/VCR
Hitachi DZ-MV550 DVD Camcorder Logo
759 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
