After reinstalling windows xp on my iqon computer, after it crashed for the second time the usb ports no longer seem to be working. And my sd card port does not seem to work. The computer did not come with a back up disk and i had to purchase another copy of the windows xp. how do i get the usb ports to work.
  • IT aid
    IT aid May 11, 2010
    hi
    what you need to do is get the drivers from producent.
    use everest to get the latest drivers
    http://www.filehippo.com/download_everes...
    more help just ask
    regards
  • 52 Answers
You must install or update the USB drivers from the web
Posted on Oct 27, 2008
I recently purchased a Canon PowerShot A3000 IS digital camera. The camera itself is working fine, but I am unable to transfer photos to the computer. On connecting the camera to the computer, the...
You do not have to connect the camera to your computer! As long as your camera uses of the following: MultiMediaCard, SD Memory Card, SDXC Memory Card, SDHC Memory Card, MultiMediaCardplus. you can insert the card into the computer's usb port and you are done! About the crashes, what is the operating system do you use? I like to know in order to help you more.
Sep 15, 2010 | Cameras
Usb 2 card is only working at low speed after reinstalling windows xp. How can I get it to go to high speed? NEC 4 Port USB 2.0 PCI Controller Card
Make sure that you have the proper driver installed for your USB interface. Your motherboard should have come with a CD, or you can go to the motherboard manufacturers website and download the latest chipset drivers.
Once they are downloaded, install them and re-start your PC. Windows XP will then recognize a whole set of new components and allow your card to run at higher speeds.
You are looking for the PCI Bridge driver in particular, but I would recommend installing ALL the drivers that are available from the motherboard manufacturer.
Jan 22, 2010 | SYBA (SD-NECU2-3E1I) (SD-NECU2-3E1I) USB...
Upload video data to computer.
how do you upload ,by using sd card or usb port?
Dec 26, 2009 | Panasonic SDR-S26 Flash Media Camcorder
My noteoook got the problem with port usb
Since you have these many problems with your laptop, Firstly try to reformat the system and reinstall all the neccessary drivers. Many times reformatting works well as your OS might malfunction when you have virus or malwares in your laptop.
OTHER SOLUTIONS
a. for USB:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  8. Close the Device Manager window.
b. SD CARD
Your 1GB kingston card might have virus. use a card reader and reformat the card for future use.
c. Uninstall and reinstall the driver of your finger scanner.
Hope this helps,
~regards,
Jegan
Jun 01, 2009 | Lenovo 3000 N100 Notebook
My usb ports for HP Compaq nx6310 laptop do not work
Probably you have not installed the correct driver for the USB port. Check whether you have any yellow "?" marks in the "device manager" window. To check that simply right click the "my computer" and select "properties", open the "hardware" tab and click the "device manager" button.
Apr 13, 2009 | HP Compaq nx6310 Notebook
System freeze
The issue was resolved by uninstalling SP3. I uninstalled SP3 and the USB PCI card and rebooted. When SP2 reinstalled the device it installed the corect driver (5.1.2600.2180) and everything is now functional. Have no idea why the correct driver was not in XP SP3.
Jan 24, 2009 | SYBA (SD-NECU2-3E1I) (SD-NECU2-3E1I) USB...
Transfer from usb to micro sd
This mp3 player does not appear to have SD card support. In general terms, however, if you plugged a USB flash drive into one USB port of your computer, and then plugged an SD card into the SD card slot on your computer, you can then double-click "My Computer," and then double-click on "Removable Drive F" or whatever your computer is calling the USB flash drive. Then, open a second instance of "My Computer," double-click on the SD Card logo, and then drag files from the USB flash window, or to the SD card window as appropriate.
Another way to do this without opening a second instance of "My Computer," would be to open up the icon for the USB flash drive, right-click on the first file that you want to transfer, and then select "Explore." The window will then change - you will see the file or files you want to transfer on the right, and all available drives (including the SD card icon) on the left. Drag and drop from there.
-Tha Mp3 Doctor
Dec 28, 2008 | RCA OPAL M4001 MP3 Player
Lan ports dont work
Where you able to check the Network adapter on the Windows Device manager?
How to verify your Network card is working properly
If you are unable to resolve the problem with your intergrated lancard then you can add additional LAN CARD on your computer or you can also buy USB to LAN CARD adapter.
http://www.techdeals.eu/electronics-store/images/tduc0205-1.jpg
Mar 07, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Computers & Internet Logo
312 people viewed this question
David Payne
David Payne
