Question about Onkyo TX-DS777
Fan doesnt turn on
I have just replaced the transisters for the second time in the long life of my DS777 but I can never remeber the cooling fan coming on and there is no dust on the fan either.
Is there any way I can change the start-up temp for the fan?
Mi jeep liberty 2002 fan doesn't turn on although i disconnect the temperature sensor, i have understood that if i disconnect it, the fan should turn on all time but it doesnt, i dont know what happens...
Having similar problem with an 03 Liberty. Replaced Radiator Cooling Fan Relay $82 and drill new mounting hole. Fan will not run after shutting off engine, so I'm thinking I have a bad thermostat or a bad cooling temperature sensor. Heading to the parts store now.
Apr 16, 2011 | 2003 Jeep Liberty
Why does a fan keep turning on and off every few seconds
Usually what you'll find is that the fan will turn on and off as the computer heats up and cools down. The fact that it turns on and off every few seconds could imply that either: a) Your computer heats up and cools down very often (not likely) b) Something is causing your computer to not sense the correct heat c) There is something impeding your fan from working properly (most likely).
I would recommend using an air duster to blow all of the dust out of the fan area and see if that improves anything.
Additionally, you can download free software which will monitor your CPU temperature, and that should let you know if you're within a reasonable range (Google for specific numbers).
Good luck! -SJ
Mar 03, 2011 | HP Pavilion A250n (DF253A#ABA) PC Desktop
My a/c comp and engine cooling fan are not working it seems like they both quit at the same time is there a sensor that opperates both on a 2001 chevy cavalier
there is a fan relay, and an AC relay that both turn the fan on at certain times, including when the AC is on. a coolant temp sensor tells the computer (ECM) to turn on the fan but only when the engine reaches a certain temp. an electronic component locator can show you where these sensors and relays are located. they are not very expensive. your local auto parts store can look that up for you.
Sep 03, 2010 | 2001 Chevrolet Cavalier
The radiator cooling fan is not working. Upon
assuming fuse and relay are fan should be running when the engine is cool/cold, the only time the fan should be running when it reach over operation temperature which then the fan kick on to bring the temperature back down to it operation temperature. both fan work in sync with one another, addition cooling is needed when the ac is running. when the last time have you replace thermostat and Thermos sensor/switch. I would replace both unit if you have not done so. The thermos/switch will turn the fan on when it reach certain temperature and cut off when it sense the temperature drop in the engine.
Aug 25, 2009 | 1999 Lincoln Town Car
Sony KDF-E50A10 50 in. HDTV LCD Television has a ringing sound like a cellular phone whenever the TV is turned on. I have isolated it to near the projector. I have taken out the projector and it still...
There are more than 1 fan in the set; however, the last one to turn off is the lamp fan. The lamp fan keeps your lamp cool and helps extend the life of your projection bulb.
You could either replace the fan, or remove the fan from the set and give it a good cleaning (that's all it might need). However, be aware, fans that go bad in these sets will start to shut down your tv and decrease the life of your lamp. Be on the lookout for intermittent or sudden shutdowns, as those can definitely indicate a bad fan.
Jul 08, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Radiator coolant fan
Some car designs only have one radiator fan as opposed to 2 fans. Typically the second smaller fan is specifically for the AC when its turned on. But with the larger single fan design, its turns on when the AC is on regardless. Now if the fan doesnt come on at all at any other time... like to prevent the car from overheating, you may want to check the Engine Coolant Temperature Sensor. Its located on the engine and easy to replace. Can be tricky to find. They only run 20 bucks thankfully.
May 17, 2009 | 2000 Oldsmobile Alero
Cooling fan won't come on, have tested fan and replaced temperature sensor.
First question to you is.. Have you checked the wiring or ECU codes?
check the cooling fan switch on the back of the block, unplug the connector and jumper.
2 wires, turn ignition on and fan should come on...
if it does-----replace the cooling fan switch
if it doesnt----- go to the cooling fan relay on the pass side inner fender
panel behind the headlight and check it, besides the fan itself and the fuse, those are the only things in the system.
May 11, 2009 | 1987 Chevrolet Cavalier 4 Door
1998 dodge caravan, engine runs on for 5 seconds, key removed...
( times out of 10 Hun its the Timein on it take it in for a Tune uP or get the Timin light and do it your Self
Mar 06, 2009 | 1998 Dodge Caravan
well if your condenser fan shot out, i'd advise that you shouldn't use the unit but all your doing buy putting the fan is doing the job of the defective one. but your causing more stress to the compressor and system, your forcing it to "work overtime" so technically you are cutting the compressor's life
May 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
The laptop doesnt start up. cooling fan is brocken. thermal oil is old and almost dry and little
Sometimes depending on the version of BIOS there is a thermal shut down feature,If the CPU gets to hot it will shut the entire system down.What you can do is replace the CPU fan and apply more grease in between the heat sink and the CPU chip.If this does not solve your problem then you may have damaged the CPU.the best way to fix this is to replace the motherboard and CPU.Try replacing the fan first because if your computer has the thermal shut down feature then chances are that it protected the motherboard and CPU from any damage.Try the simple things first! GOOD LUCK.
Nov 13, 2007 | Toshiba Satellite A45-S250 Notebook
Onkyo TX-DS777 Logo
26 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
