Question about Polk Audio Audio Players & Recorders
Where is the fuse on the polk 6750 sub woofer
SOURCE: sub woofer keeps blowing fuses
Try a 3 amp fuse
Posted on Jun 24, 2008
SOURCE: blown fuse on sub woofer
1 amp 250-volt from radio shack #270-1021
Posted on Jul 24, 2009
Grubhead
  • 5259 Answers
SOURCE: Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Posted on Jan 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: Polk Audio DSW Pro 500
Is this NEW? Or did it just fail spontaneously after working for awhile?
Is this just a remote control issue or is the sub dead, too?
From the manual...
No sound coming from subwoofer.
If hookup is "SUB OUT" to LFE, check and make sure your receiver is set to Subwoofer=YES. If hookup is via speaker wire, check that the polarity of the wires is correct.
Subwoofer has no power.
Is the AC MAIN switch on? Check outlet; check fuse after unplugging the subwoofer. The fuse is located under the power cord
receptacle. Fuse type and rating is found on the back panel.
Remote control doesn't work.
Remove the plastic tab to activate the remote control's battery or try replacing the battery. Ensure the IR sensor is not blocked.
If it's a new problem with a previously working remote...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
It describes a way to possibly fix your remote or at least prove it works or doesn't.
Find new or replacement remotes:
http://remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=A12992635562861
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Posted on Mar 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: Polk Audio PSW300 What is the
IAW the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-791-Receivers-manual/id/23693ag505/t/2/
Page 5
Posted on Apr 18, 2011
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
What could be the issue with my sub woofer power?
Many of these SUB amps ended up with Capacitor failures in the Power supply section . Find someone who works on amps or TVs to have a look see.
May 26, 2014 | Polk Audio Polk DSW PRO 550WI Subwoofer
Jan 15, 2010 | Polk Audio PSW10 Subwoofer
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Whats the rateing on the polk 10 inch sub woofer
Hello dread2477,
The Polk Audio db1040 is a single voice coil 4ohm subwoofer. The db1040DVC is dual voice coil with 4ohm coils which can be wired in parallel for a 2ohm load, or in series for an 8ohm load. They are practically the same sub. The RMS power range is 50-270 watts, with a maximum peak power of 540 watts.
The full specifications including recommended enclosures and physical dimensions can be found here.
Hope this helps.
Aug 03, 2009 | Polk Audio Car Audio & Video
Jamo Cornet 90 IV Speakers - Woofers need replacement
I had the sub woofer problem what i did was i found the fuse in back of the unit i took it out with a srew driver. I looked in the light to see if the tube had a smoke shot in it and it did then i got some aluminum foil just a tiny piece and put it around the tube and low and behold my unit pop back on what a relief. The foil is for testing only you need a fuses to not cause a fire!
Posted by charles on Jan 12, 2009
Jan 12, 2009 | Audio Players & Recorders
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
