Question about Cameras
I have a Philips 9FF2 series photo frame which has just stopped working. I took an sd card out the screen went black and it will not work even when using the reset button. I have unplugged it, tried the reset button but nothing happens just a black screen. The blue light on the on button is working. Thanks Lynne
  • ferrari1 Jan 05, 2009
    I have exactly the same issue - the blue light comes on if I plug into the mains, but I just get a blank screen. The frame has been working fine for about a year..
  • dave bramley Jan 20, 2009
    I have a Philips and it has just stopped working exactly the same symptoms as the other 2 people. Blue power light glows. Screen black and dead and nothing including pressing reset brings it to life - I was removing a memory stick when it went although the controls had started playing up just before it died.
SOURCE: Insignia digital photo frame won't recognize some .jpgs
When you save in Photoshop make sure you select "Baseline ("Standard") on the JPEG options when you save. That should fix the problem for you. It did the trick for My Kodak SV710 digital frame which wasn't displaying images I had edited in photoshop.
Posted on Apr 03, 2008
  • 203 Answers
SOURCE: I bought two 4 GB
pny does not supply card readers w/memory cards-sandisk on certain cards includes reader because file format is different on sdhc cards -try downloading direct from camera w/usb or get a card reader that absolutley supports sdhc type cards-not all readers do!
Posted on Jun 25, 2008
SOURCE: Doesn't work at all!
Daft question, but are the batteries fully charged?
Lens cap off?
When you hit the menu/ok centre button, do you get the menu screen up?
Posted on Aug 27, 2008
SOURCE: i bought a technika jp07
It seems that it's not about the size of file or resolution of the photo!
I was given one of these yesterday. I copied my photos on to a 64mb SD card of unknown make. They display fine on my PC but on my Photo Frame I get the "no playable file" message. I tried changing file size etc but no good.
As a last resort I copied my same photos on to a 2GB SanDisk SD card and tried that. It works fine. So my guess is that these photo frames are picky on what SD card they'll accept.
A pity the manual doesn't tell you so!
Posted on Dec 30, 2008
  • 11967 Answers
SOURCE: Won't read my SD Card
Try resetting your camera. Go into the menu and scroll to "reset" and follow the on-screen instructions.
Posted on Nov 18, 2009
Pandigital Photo Frame will not read MMC card
The new card is not compatible with your photo frame. Only thing you can do is to make sure that what you use is compatible. Your manual or website will tell you the largest memory card you can use.
Aug 27, 2016 | PANDIGITAL 7" Digital Photo Frame With...
What is the maximum size of a SD memory card that the Philips digital photo display model 9ff2 can support?
The maximum size of an SD card is 2GB, and the 9FF2 will support SD cards of that size. The 9FF2 will not support SDHC cards, which start at 4GB and go up.
Mar 29, 2012 | Cameras
My Philips 9FF2CME/37 photo frame no longer holds a battery charge. How do I access the battery so that I can replace it? What type (make/model#) battery?
the Philips 9FF2 photo frame has an internal rechargeable battery inside the photo frame. So in other words, the Philips 9FF2 photo frame needs to be disassembled for you to be able to access the battery, then make necessary replacement.
With the Philips 9FF2 photo frame turned off and remove from the charger, get a screw driver, use it to disassemble the unit to take the back cover apart in order to gain access to the internal part to get to the battery.
Remove the battery, take it to any electronics part store in your area and get a battery replacement. It is not necessary that you get a Philips battery, all you need is a battery with the same size and volt/watt.
I hope the above is clear.
Regards.
Jul 18, 2011 | Philips 9ff2 Digital Photo Frame
My Philips 9FF2 photo frame no longer holds a battery charge. How do I replace the rechargeable battery?
Good luck.
I have a Philips PhotoFrame - SPF3408/G7 (SPF3408T/G7). When plugged in no picture comes on screen. Screen does not light up. I viewed pictures yesterday - but - I don't get anything today. I know...
Keep in mind that Digital Photo Frame can display the same photo continuously for 1000 hours without any damage to the LCD screen.
If you can enter to the settitgn menu, first make sure the system is properly powered. Then use a pin to trigger the reset button located on the side of the power button on the back to restore the system...
If this isnt work try...
  1. Load all the photos you want to upload to the Photo Frame in the root directory of your memory card.
  2. Power off your Photo Frame by pressing the Power button.
  3. Insert the memory card into the slot in the frame.
    A For a Compact Flash card, firmly slide card in the larger slot end first and face down.
    B For an xD, SD, MMC, or Memory Stick card slide card in the smaller slot end first and face up until it locks into place.
  1. Restart Photo Frame by pressing the Power button.
  2. After a few seconds, all photos in the root directory of the memory card will be automatically added to Photo Frame. The root directory on memory card will not be emptied after this operation.
    Please do not remove the memory card just after inserting it in Photo Frame or when Photo Frame is counting the Photo.
    Wait until the screen is stable.
    NOTE: This operation does not apply to photos in sub-directories.
If anyone of this procedures work fine, I suggest contact your local service (check if even is underwarranty).
Good luck.
Jul 05, 2011 | Video Game Consoles & Games
I have a cracked screen for a Phillips photo frame 9ff2
A new LCD screen can coud about 15 to 20 USD (eBay).
Then see this tutorial: http://www.youtube.com/watch?v=u-5eDINc35s
Good luck
Jun 23, 2010 | Cameras
Hiya, I have a philips photo frame 9FF2
It seems that SD cards bigger than 2 GB are not supported by this photo frame... I have the same problem tsssss...
Jan 03, 2010 | Philips PhotoFrame -10 Digital Picture...
Hi, i can only copy some jpeg images to my 8FF3FP digital photo frame and not others, any ideas why???
it only will show jpeg images no other formats show.
Technical information sheet of 8FF3FPB/00 - 8" (20 cm) Digital Photo Frame - Black + 1GB SD Card With the Philips 8FF3FPB/00 digital photo frame, you can show off all of your favourite digital photos in style!
Its 8" 4:3 screen has a resolution of 800 x 600 pixels, so with the 8FF3FPB/00, you don't need to resize your photos. Plus, the 8FF3FPB/00 uses ImagEn technology to ensure your photos always look their best on this clear, bright display.
The Philips digital photo frame is also an ecological choice, because its SmartPower function allows you to save a considerable amount of energy.
General Device Type Digital photo frame Key Features Digital photo viewer, memory card reader Width 24.5 cm Depth 12.1 cm Height 16.7 cm Weight 494 g PC Interfaces USB Features Auto power off, clock, USB host function, alarm, auto power on Localisation Belgium, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Indonesia, Israel, Lithuania, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Iran, Pakistan, Romania, Thailand, Malaysia, Singapore, Luxembourg, Hungary, India, Bolivia, Uruguay, Honduras, Guatemala, Panama, Algeria, Morocco, Bangladesh, Philippines, Croatia, Kazakhstan, Slovakia, Slovenia, Korea, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Russia, Spain, Sweden, Switzerland, Greece, Turkey Display Display Type LCD 8" - colour Display Form Factor Built-in Image Aspect Ratio 4:3 Image Contrast Ratio 300:1 Image Brightness 250 cd/m2 Display Format 800 x 600 Status Information Card, firmware version, memory Display Features Brightness Memory / Storage Flash Memory Cards Supported CompactFlash Card type I, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, SDHC Memory Card Digital Photo Frame Operating Modes Landscape, portrait Features Variable slide show speeds Still images Supported Still images Formats JPEG
Nov 30, 2008 | Computers & Internet
Cameras Logo
296 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
