My computer was working fine, but was very dusty. So I took it apart and blew out all the dust and cleaned it real good. Put it back together and now it's louder than ever. Don't know if I damaged the fan or didn't put it back together correctly. Any advice?? Thanks
sounds like the fan is on its last stand..replace it..
Same Problem
Feb 20, 2009
-   I Have sun ultra 24 High end work station it is giving error in BIOS as CPU fan error and key board not functional. when we remove System fan noise is gone.so we replaced new System fan again noise is coming.still problem is there. we did following things. 1.)BIOS updated 2.)Replaced CPU fan and system Fan. kindly suggest any solution if any body has faced same problem.
-   locserc
if the fan sound is very loud, there might be 2 probabilities-
1) you haven't connected it roperly-
2) the fan is losing its life-
so its better to replace it as you can get it for lower prices everywhere..!!
Check that the fan is not hitting any wires in side the case.
If not you may have disoriented the fins while cleaning them. Make sure the fins are not hitting the fan body.
If the fan wasn't installed property the CPU temprature should rise fast and your computer might automatically shut down to prevent damage to the CPU. If that is the case, try reinstalling it making sure it's attached well to the CPU. And remember to add some thermal compound to help the heatsink transfer heat.
If none have solved your problem you can buy a new fan for your CPU at any computer store. Make sure it's compatable with your CPU socket type.
my crt monitor colours ae changed after a while and return back after some time my monitor is...
(More)
my crt monitor colours ae changed after a while and return back after some time my monitor is microtek flat vision model
When I open the Arc-Soft software, it will show my face in the video screen for a second then switch...
(More)
When I open the Arc-Soft software, it will show my face in the video screen for a second then switch to a screen of the software name and I cannot get it to go away. I've rebooted, made sure it is connected, EVERYTHING! HELP!
I am running Vista and using Media Center. After 2 months the AVerMedia M791 PCIe Combo has stopped...
(More)
I am running Vista and using Media Center. After 2 months the AVerMedia M791 PCIe Combo has stopped working, Media Center says no antenna input. I have verified the antenna works by installing a Hauppauge USB TV Tuner pn the PC. Have tried reinstalling drivers and hardware and still nothing. Any other recommendations besides replacing the tuner card?
