Question about Kenmore 15218 Mechanical Sewing Machine
Bobbin winder won't turn - Kenmore 15218 Mechanical Sewing Machine
    New Friend:
  • 46 Answers
I sounds like she only needs to push from the left position ot the right and be sure to pull out the hand wheel. It's a common mistake for people to forget to push that bobbin psindle over to get the bobbin ot spin. It doesn't sound broken to me ...I dunn no. Just trying to help!
Bonnie
Posted on Jul 29, 2008
The bobbin winder won’t spin
hi margene.
go to this link and see if it helps you out.
sewing machine bobbin winder won spin Google Search
Nov 06, 2017 | Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Bobbin won't wind on Singer futura CE-100
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
Sep 09, 2012 | Singer CE-100 Futura Computerized Sewing...
Brother VX1435, needle won't move
some machines when the bobbin winder is engaged will not sew, do you
have to disengage the center wheel in the handwheel to wind a bobbin?
or do you have to just move the bobbin winder spindle to the right to
wind the bobbin?
do you have a manual for the machine?
Sep 06, 2012 | Brother VX1435 Mechanical Sewing Machine
My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
The bobbin may be stripped, or the bobbin winder might be stripped; try it with a different bobbin, to rule out the bobbin being the issue; if that doesn't work, look closely at the bobbin winder to see if it has been damaged. You may be able to adjust it's shape with a pliers
Apr 02, 2012 | Singer 3116 Simple
The bobbin on my kenmore sewing machine model 158.15720 won't spin to wind the bobbin. I oiled it but it didn't help. The belt is a little loose. Could replacing it help?
most machines will have a rubber o ring as part of the bobbin winding mechanism, when you engage the bobbin winder, this o-ring will move over against the main engine drive wheel and this then makes the bobbin spindle turn. So yes, you may need to replace the rubber o-ring, they can perish and wear. Called Bobbin Winder Tyre, you could try www.sewingpartsonline.com, they have loads of Kenmore models listed but can't see yours. However, if you email them, they should be able to advise what part number it is. If you start by opening up the machine case and take a look at the bobbin winder area first, you may find this rubber has split or perished.
Oct 11, 2011 | Elna 2007 Mechanical Sewing Machine
My machine will not thread any bobbins.
Your bobbin winder has seized. Remove the top cover and oil the area where the bobbin winder shaft goes through the bobbin winder assembly. You might need to force the winder to turn with your fingers for a while, but it will begin to turn smoothly once the oil gets in there.
If the black bobbin winder tire has a flat spot worn into it, you will need a new bobbin winder tire. Costs around a dollar.
Apr 07, 2010 | New Home L-372 Mechanical Sewing Machine
Bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at sewusa.com.
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Mar 13, 2010 | Kenmore Sewing Machines
Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
Kenmore 15218 Mechanical Sewing Machine Logo
158 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
