Question about Epson Perfection 2450 Photo Flatbed Scanner
Epson 2450 scanner
Scanning in colour puts a blue tinge to half the image, and black text turns blue over the same area
  • reverie3 Mar 10, 2009
    I am having a similar problem where my scanner suddenly started scanning everything in blue. The color is monochromatic so I can't even fix it. All film I scan is blue unless I'm scanning normal documents. I tried moving it and using a new cable. What is causing this?
    Scholar:
  • 111 Answers
Without knowing all of the details and features of the Epson 2450 scanner, my first suggestion would be to calibrate the scanner. There is usually a calibration option within the scanner driver. If there is some sort of "Advance" mode in the driver, this option would most likely be there. If there is no change after this, then I would suggest to turn the scanner around (180 degrees) so that the front of the scanner is now where the back is. This is simply to see if there is interference coming from the area on the side of the scanner on which the blue tinge was noticed. So if you turn the scanner around and the blue tinge moves to the other side of the scan, then you know there is some type of interference, in which case you could move the scanner away from that specific location, temporarily, until you could locate the source of the interference. Assuming this is USB, you may consider trying a different USB cable. Try to limit the cable length to 6ft or less. Connect the USB cable directly to the computer (for testing purposes) as opposed to connecting through a USB Hub or some other device. If all has failed to resolve the issue, trying the scanner on another computer would be ideal. If the problem still exists, then service will most likely be required.
Hope this helps.
Posted on Oct 27, 2008
Epson Perfection 2450 Photo scanner won't run on Win 7 Ultimate.
is windows 7 32 bit version or 64 bit version . Suggest downloading drivers that match the windows 7 operating system and installing them.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14558&infoType=Downloads
Mar 22, 2015 | Epson Perfection 2450 Photo Flatbed...
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
How open case to Epson Perfection 2450?
go to Epson.com tghey should have the solution if not email me at mike.athome@vodafone.co.nz
Feb 05, 2009 | Apple Epson Perfection 2450 Photo Flatbed...
When I scan colour slides the image gets cropped
Uncheck the option that says "Thumbnail" and draw individual marquees for the area on the slide you want to scan. Not very elegant but it works.
Dec 31, 2008 | Epson Perfection V700 PHOTO Flatbed...
Slide scanning with Epson Perfection 2450
I don't know if this is truly a "solution" or not, but I get the same thing on my HP 4850 scans. After scanning, I just crop the pictures to remove the black borders. Can you do that?
Dec 08, 2008 | Epson Perfection 2450 Photo Flatbed...
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Epson Perfection 2450 Photo Flatbed Scanner Logo
265 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
