Question about Car Audio & Video
I have 2 tview t921pl and have no power/video supply how do I hard wire them I know which ones are the videos no the power and ground colors are orange purple green brown red
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
TBlessed 1
  • 61 Answers
SOURCE: ceiling fan wires
is the old fixture still installed?
Posted on Oct 17, 2008
johnny5846
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
What are the white, blue and black wires for on the Tview T1508IR-BK swivel?
Power ground video hopefully that helps out. You need a compatible radio also that support video
Dec 14, 2014 | Dryers
I have a tview in dash dvd player it is d7905bd I am getting no sound and it has a blue screen and the little screen says back c 4 r any solutions
if you connect the brown safety ground wire to the black ground wire it should start working, mine was doing the same thing and that got it working.
Apr 11, 2011 | T-View Dvd7905bd Car Video Player
How do i bypass the safety ground to watch dvd without pulling the parking park??
This can be done, although may not be legal in some states. Look around on google. Just know that there is a reson the park kill feature is there in the first place.
Dec 23, 2010 | T-View TView (DVD170TV) Motorized 7"...
How do i take the dvd safety feature off so i can drive with the dvd player on..
There is a wire that you are supposed to hook up to your emergency brake or another source to let it know your are parked. That same wire usually relies on a ground. I just grounded mine to a good ground under the dash and it worked great. Hope this helps and good luck!
Jul 10, 2010 | T-View TView (DVD170TV) Motorized 7"...
CANT HOOK UP MY TVIEW T56UN/HR 5.6 LCD MONITOR
THE S-VIDEO LOOK ALIKE IS ACTUALLY A PIN ADAPTER FOR AV JACKS. THE DVD MAKERS USE SPECIAL CONNECTIONS TO COMPLICATE ADDING TO MIXED SYSTEMS. (THEY WANT YOU TO BUY ONLY THEIR PRODUCTS!) REPLACEMENT ADAPTERS ARE AVAILABLE ONLINE @ http://www.tview.us/
Jan 18, 2009 | T-View TView (T606HR) 6" TFT/LCD Monitor...
TView headrest dvd player
hi hallow then their is a problem in passing power supply or receiving power supply r some where the connection may lost which unknown to u so please refer it once again and see the battery connected perfectly are not. u explained u r problem very well but such problem can solve by cheaking the instrument practicaly so if still u r problem is not solved its better to consult the expert near to u directly
Feb 24, 2008 | Car Audio & Video
WIREING
Not familiar with that brand, but it should use the international standard colors: yellow- battery red- ignition black-ground white- left front + white/blk- left front - gray- rt front + gray/blk- rt front- purple- rt rear + purple/blk- rt rear- green- left rear+ grn/blk- left rear -
Sep 13, 2007 | T-View TView (DVD170TV) Motorized 7"...
Car Audio & Video Logo
197 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
