Question about Sewing Machines
Needle wont go down
When trying to stitch the needle only goes down to right above the plate and then stops.
  • Sewing Machines Master
  • 7,365 Answers
Sounds a part of the machine is either broken or loose
it need to be check by a sewing machine repair shop
Posted on Feb 21, 2012
bargainbox
  • 1388 Answers
SOURCE: Needle hitting bobbin plate
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
Posted on Feb 10, 2008
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
SOURCE: EURO PRO 6131 Sewing Machine not maintaining stitch
http://www.sewusa.com/Sewing_Machine_Instruction_Manuals.htm
Posted on Sep 04, 2008
  • 15 Answers
SOURCE: I have a white superlock 228 jaguar serger problems with right needle
Couple of things I could think of: tension disks need cleaning, there is a site that tells how to clean them, maybe 2 as I recall. Other thing is it is a much older serger, (I have one I am slowly working on to bring up to working level), so it could be that a tension spring internally has lost its tension. It might need a trip to the repair man if that is the case. Another thing is are you using correct needles for the machine? Have you changed them recently? Even new needles can be bad, so if you have to change three times to triple check it can be worth it.
Posted on Sep 09, 2008
SewExpress
  • 41 Answers
SOURCE: 2020 rotary hook continuous one direction pfaff tiptronic 2020
You are absolutely correct - your machine doesn't come apart much because it is an electronic machine. There really are very few moving parts in modern sewing machines - and the electronics are better left to a technician who's been specifically trained.
It sounds as if your machine is no longer in time (needle rubbing the plate as it goes around if I'm understanding correctly). While not really a "major" repair, unfortunately with computerized/electronic machines, retiming your machine is something better left to an authorized Pfaff technician.
If the needle struck metal as you were stitching/basting, there may also be a rough spot/burr on the hook that your technician will be able to smooth off as well.
Hope this helps get you back up and running soon.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
How do I keep my sewing machines top thread from hanging up on something under the plate?
Hello
The description seems to indicate that the top thread has no to very little tension. Try rethreading the upper thread and make double sure that it is engaged in the tension assembly AND goes through the take up lever (that is the little 'thingy' that goes up and down really fast as your are stitching).
Generally loops on the underside are caused by loose thread on the top.
Happy stitching
Sewingirl/
Apr 23, 2017 | Sewing Machines
Singer ce-200 stops sewing
Double check your threading,
1 first point to enter for tread (a).. then around little cog down and up again down.to needle thread it (b)
at A tuck on it.. make sure foot is up.. you will hear a loud click pulll thread down.. thread needle now while threaded... see that long metal horizontal plate under the machine but above the needle.. pull the thread behind it.. if you look at it you will notice the natural flow path.. you will hear a tiny click thats the sensor.. ok back to the top... where you first threaded the thread give it another little tuck you will hear a tiny click.. ok.. sensors seen the thread..
now unless your tensions are wrong.. it all should run.. with the right thread and materials.. also is the bobbin in ok? it unwinds anti clockwise.
May 13, 2012 | Singer CE-200 Quantum Futura Computerized...
I have a bernina activa 130 and when you turn the wheel to insert the needle into the fabric the needle breaks. I am not sure what to check.
Check that your needle is centred when straight-stitch is selected and / or that you have the correct stitch-plate fitted. Is the needle breaking because it is hitting the stitch-plate or is it breaking when the needle goes down through the slot/hole in the stitch-plate. If you are sewing zig/zag or patterns, you must have a slotted stitch-plate fitted. If it's breaking when the needle passes below the stitch-plate, then take the bobbin /bobbin case out and the hook/shuttle and see if it still happens. If it does, the timing on your machine may be out and need professional adjustment. If it doesn'y happen after removing just the bobbin case, make sure the bobbin case is being correctly fitted.
Sep 19, 2011 | Bernina Activa 130
I have a Bernina Activa 140. The threaded needle is not catching the bobbin thread. What should the needle height be from the plate?
The needle height is best checked by rotating the handwheel until the needle goes down through the stitch-plate (Make sure you're using a zig-zag stitch plate and not a straight stitch plate) and just starts to come back up again. Stop there. Gently push the needle bar to the right until the needle is at its furthest-most travel right (next to the right-hand edge of the needle slot). Tip the machine backwards slightly and drop the bobbin door; take the bobbin out. Open the hook/shuttle retainer, but leave the hook/shuttle in the hook race. The point of the hook/shuttle should be somewhere near the top, just below the stitch plate. Slowly rotate the handwheel until the point of the hook/shuttle passes just behind the needle; The point on the hook/shuttle should be just above the thread hole in the needle - if-so, the needle is at the right height, assuming the machine is properly synchronised. If its at the wrong height, you would need to have the needle-bar mechanism adjusted to put it right (relatively simple) - you cant just try and fudge it by adjusting the needle height using the needle securing screw. If you need help with re-setting the needle bar to get the right height, I can help, but you really need to be sure that the machine is properly synchronised first, so this may not be the total solution. Hope this helps.
Aug 25, 2011 | Bernina Activa 140
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
Older 830 will not zig zag stitch. leavers and gears move fine. The needle moves back and forth - left and right but it doesn't pick up thread from the bobbin on the left side so it does a strait stitch...
Firstly, make sure you have fitted a new needle and that you have cleaned/oiled the hook race. Unfortunately, if you are finding that the machine will pick-up the thread and stitch OK when the needle is one side of the stitch-plate, but not when its on the other, it suggests that the timing/synchronisation is out and will need to be professionally adjusted. You can check the timing by adjusting the needle to its right-most position, remove the bobbin case, rotate the handwheel until the needle has gone down through the stitch-plate and is just about to come up again. Stop there. Tip the machine slightly back and release the black plastic hook/shuttle retainer by pressing the metal lever on the top-left side of the bobbin door, so that the hook/shuttle retainer pops open. Drop the hook/shuttle retainer, but leave the hook in place ... be careful that it doesn't drop out and slowly rotate the handwheel until the pointed part of the hook/shuttle rotates clockwise to the place where its point is directly behind the needle. Look carefully and you should see that the point of the hook/shuttle is just above the top of the thread hole in the needle. If it's much lower or higher, the timing is out and will need to be adjusted.
Feb 06, 2011 | Bernina Activa 130
Tl98e broke a needle and now won't stop looping.
needle plate may be sanded lightly for nicks and scratches. Timing is probably off, need to see an expert repair service in your area.
May 30, 2010 | Feiyue FS288
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
