Question about Acer AL Computers & Internet
Acer Al1912 picture off center
I use the Acer AL1912 display on my docking station. Any time the laptop comes out of power saving mode (where the monitor is off) the entire raster is shifted up and to the right (by approx 1/2 inch). I need to hit the "Auto" button on the monitor to re-center the display on the monitor.
SOURCE: acer al1912 19" black
See if the problem happends in safe mode ( while booting hit F8 and aboot menu wil come up) if everything works fine then your issue will be the driver or a resulition that the display does not support or a refresh rate. Frist try to change the Res to a lower one and common (1024X768 or 800X600) also change the refresh to somewhere 70 to 75 and reboot if this dosent fix the problem try updating your video driver in safe mode
Posted on Jul 09, 2008
SOURCE: Acer AL1912 Monitor
ditto here, hopefully someone will have a solution
Posted on Jul 20, 2008
freetek
  • 5568 Answers
SOURCE: My acer AL1912 monitor keeps going fuzzy. It kind
An unusual problem for a flat screen monitor.
I suggest you connect the monitor to another PC to see if the problem persists since it could also be caused by the video card (or circuit, if on board).
Check your cables making sure they are solidly connected and wiggle them to see if you can cause the problem to come or go away; this would crudely check the shielding of them.
This kind of aberration could easily happen with a conventional CRT monitor if power supply filtering was failing but as mentioned, uncommon in a monitor that is essentially digital.
Posted on May 12, 2009
freetek
  • 5568 Answers
SOURCE: i have a acer al1912 faulty
It might be worth a try but the two different sizes could have differing resolutions and if they do, the boards are not likely interchangeable.
  • 3940 Answers
SOURCE: Any Drivers for ACER AL1912
With very few exceptions, LCD monitors do not require a driver. Almost always, and display setting issue is an issue with the Display adapter (Video Card) driver. The plug and Play monitor driver that is native to Windows should work just fine.
Posted on Jun 13, 2009
I boot up the PC, the acer sl1912 comes on then goes into sleep mode in a few seconds
You can perform a test by plugging it into another PC/laptop to see if you can get the display. If it doesn't work there, you most likely need to replace/repair your screen. If it does, then it means that there is a problem with your PC's video card.
Mar 03, 2011 | Acer AL1912 19" LCD Monitor
How can I connect my Fujitsu Siemens key board with my Acer AL1912 monitor? There is a connect button on the key board, but where is the connect button on the Acer?
Is it a wireless keyboard? If that is the case, then you should have a receiver unit attached to the PC, usually to a USB port. The ACER is justt a monitor, here is the user manual: http://www.retrevo.com/support/Acer-AL1912-Monitors-manual/id/719ag115/t/2/
Jan 20, 2010 | Acer AL1912 19" LCD Monitor
Jun 13, 2009 | Acer AL1912 19" LCD Monitor
May 12, 2009 | Acer AL1912 19" LCD Monitor
I have a acer al1912 faulty
Jan 29, 2009 | Acer AL1912 19" LCD Monitor
No Signal
Not all monitors can display the same resolutions. You may have has the Dell monitor set at something the Acer can not handle. Try rebooting and if you can see the Dell startup screen press F8 as soon as it disappears. This will give you the Windows Startup Options menu, which is text and should display on any monitor. Then select VGA MODE, which is the lowest common denominator for graphics. You should be able to see the Windows display at a much lower resolution (ie, larger fonts and icons) than usual until you can reset your graphics properties to work with the new monitor.
Dec 28, 2008 | Acer AL1912 19" LCD Monitor
No display
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
Jul 30, 2008 | Acer AL1912 19" LCD Monitor
Acer al1912 19" black
Jan 09, 2008 | Acer AL1912 19" LCD Monitor
Acer al1912 with S3inc trio 32/64 card
start with a 1024x788 60hz refresh , connect lcd
and then try any higher freq/refresh as it will ask you to verify.
Nov 02, 2007 | Acer AL1912 19" LCD Monitor
Acer AL1912 Monitor Looping
I have fixed many of the al1912 easy fix
the problem is always corrosion on the circuit board that has the buttons
disassemble the flat panel remove 3 screws that hold button board on
disconnect the tiny cable from the button board
use a tooth pick and clean inbetween the solder connections where the ribbin cable plugs into button board
Apr 10, 2007 | Acer AL1912 19" LCD Monitor
Computers & Internet Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
