Question about Neff H5470 Microwave Oven
NEFF H5470NOGB Microwave door latch fault
My H5470NOGB has developed a fault with the door. The door opens but when you close it it will not latch. The light and the clock works but you can't microwave of cause
  • Anonymous Mar 15, 2014
    Neff microwave door doesn't close
    Sergeant:
  • 228 Answers
Theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Posted on Aug 05, 2009
  • 3 more comments
  • John Sep 04, 2012
    I had the same prob...did as you told but Can't find the spring...
  • colin young Mar 28, 2013
    This worked, thanks. Not sure whether the spring will snap under increased tension, think it should be OK.
  • Phil May 04, 2013
    Great advice, worked a treat for me. The small piece of plastic that the spring hooks had snapped, I glued that with araldite and all is fine. Thank you.
  • Diggory Orr-Ewing
    Diggory Orr-Ewing Apr 18, 2014
    Hello, This page started my search as my Model developed the same symptoms. There is a great Youtube video show how to remove the door frame.https://www.youtube.com/watch?v=nIdT4kS3... I did that and indeed found the spring hanging loose. The Plastic hook was snapped from the body of the door also. I couldn't see how glue would be strong enough so here's what I did. 1, beneath the snapped hook there is a 'square' of door frame about 1cm x 1cm. I then fashioned a square wooden peg about 1.5cm long and the same dimensions wide as the 'square' recess. 2, Into this I drilled a very thin pilot hole. 3, I then used two pairs of needle-nose pliers to bend the end of a thin small nail over into an 'L' shaped. 4, Then tap this carefully into the pilot hole, it should be a snug fit. Be careful not to split wood. I used Pallet wood. N.B. Make sure you leave a tiny gap on the left hand side of the wooden peg, this is so the internal door frame can squeeze in again - IMPORTANT. 5, This was then inserted into the recess with the hook of the nail facing down. 6, reattach the spring and push back into place the doorframe. Hey presto, it worked and will probably be better than the original plastic hook for sure! Cheers All.
  • Anonymous Sep 14, 2015
    Hi - Thanks for the good advice - It was easy to take door apart - I attached the spring to the inner metal frame with a cable binder - super easy. But it is really a silly construction - looks like "sollbruchstelle" (german for piece designed to break)
    New Friend:
My top tab broke whiich guides the latch up and down. what a stupid design. plastic will degrade over time. i macguyvered a solution fixing the broken tab to the latch and holding in place with elastic bands around the guide post. now the plastic tab slides up and down against the door frame,rather than the post sliding through the tab when it was attached to the door frame. just a flimsy design. but thanks to the solutions posted i figured out how to get in there.
Posted on Jan 15, 2014
My microwave intermittently blows the downstairs sockets
If it is tripping the breaker when you just close the door, I think it might be one of the door switches that the latch activates. There are usually 3 switches behind the latch holes in the microwave. One is a safety monitor switch that is suppose to blow the internal fuse if the microwave is started and the door is not closed properly. It should blow the micro fuse before the house breaker unless you have a weak house breaker. It will do the same thing if start is pressed and it senses a problem with the door. You say the problem is intermittent so I assume you do get it to work at times so I'm guessing most of the microwave is OK. I'm pretty sure you have a door switch problem--- either out of adjustment ---or 1 of them going bad.
Apr 03, 2014 | Neff Microwave Ovens
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
The button to open the door doesn't work so the door is permanantly shut
you will find there is a broken plastic latch this part will need to be replaced you can open the door if you take the top off and manual lift the latch
need more help let me know
Jan 18, 2011 | Neff H5642 Convection / Microwave Oven
My h5470nogb/03 900 watt microwave cuts out after 20 seconds what is the problem please
Possibly the magnetron is not producing power and as the cavity temperature is not rising, it cuts out.
Is there an error code in the display?
Jan 02, 2011 | Neff H5470N0GB Microwave Oven
NEFF H5430NOGB Integrated oven - door won't close, the ;hooks on the door itself seem to have gone loose so they ill not clikc inot place when trying ot close, door just flops open.Amy ideas???
I had this problem. The spring inside the door which pushes the the latches down had broken (plastic peg had broken off).
I managed to fix it by attaching the broken end of the spring to the door frame using a small nylon cable tie using the small hole in the plastic fingers which was already there. Note you need to remove the inside door surround.
See the following link to remove the plastic cover on the door
http://www.fixya.com/support/t1267577-replace_front_glass_door_neff_microwave
I had an interim solution which was to tie some thin string to the latch and feed it under the door and pull on the string when closing the door (when it should be latching.
It was
Dec 06, 2010 | Neff H5430 Convection Microwave Oven
Neff 5470 used for 20 min then just cut out
Take it back to where you bought it from and get a new one!
May 19, 2009 | Neff H5470NOGB 900 Watts Microwave Oven
Broken front glass door
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 20, 2008 | Neff H5470NOGB 900 Watts Microwave Oven
Neff H5470 Microwave Oven Logo
3,064 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
