Question about Yard Machines 155 Torque Briggs Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000
How do I fix a flooding Yard Machine 12.5 hp riding mower with an over flowing carb
When the mower is turned off gas leaks from the carberator
flyer4play
SOURCE: Yard machine 139cc will only run short time with choke
i have the same problem with my 139cc model, but no leaking gas. it just runs in choke on only.
uuuughhh!!!
Posted on Jun 10, 2010
SOURCE: Yard machine carb issues
clean the main jet and check the pickup tube if this carb is a tank mounted side draft carb.
Posted on Jul 19, 2010
SOURCE: my yard machine 14.5 hp briggs engine with 42
It’s a bad solenoid. Mine was located under the shifter plate?
Posted on Aug 08, 2010
SOURCE: I have a yard machine
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Posted on Aug 18, 2010
budgie140
  • 501 Answers
SOURCE: cant get the nuts off the blades on my yard
use a six sided socket,or disc cut the nuts off ,split down one side,and renew
Posted on Apr 16, 2011
I have a yard machine 742rl when gas I'd in tank and fuel line hooked up gas floods out carb and fills up Air cleaner as if there is nothing to stop and start flow of gas
Those carbs have a nitrile rubber needle and seat.
When the rubber becomes worn, they leak and need to be replaced.
This is not something the average guy can do so it's simply easier to replace the carb.
That should solve your problem.
Apr 18, 2016 | Garden
I have a murray riding mower, 10hp, 30'' I filled my gas tank and 2 days later the gas was gone. but I did not see a leak. in the tank
check to see if gas running out of carberator also check your oil make sure gas is not in there if it is or fuel running out of carb replace needle and seat in carb check for cracked seam on gas tank also make sure fuel line not leaking
Sep 15, 2014 | Garden
Starting and running
change your plugs take the old gas out check your oil make sure its clean and at the right level check the air filter clean it if nesesarry change fuel filter. if not of this works check to see if it is grounding out look over the machine while running it in the dark if you see a spark some were look it over fix it if none of this works you may have do get a carberator kit your highspeed needle is what usually goes just make sure you count the number of turns when you take it out/
Apr 06, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine starts then backfires and sometimes leaks gas on exhaust
IS it leaking gas on the exhaust or thru the exhaust. I have seen the float in the carb stick in the down or fill position and flood thru the exhaust.
Sep 04, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
Adjusting a craftsman dlt 3000 riding mower carberator so it will not flood engine
assuming that you are working on a briggs engine? regardless of make what the problem is that the needle and seat inside the carb is not sealing off the fuel flow from the fuel pump/fuel tank or both......gravity feed fuel systems are the worst about flooding, the only fix will be a carburetor repair with needle and seat replacement
Nov 25, 2009 | Craftsman Garden
The carb on my mdf lawnmower is flooding is there adj on this type of carb it is 15 years old and has not been run untill this summer , now it does not stay running
I am unsure if this will fix your problem, but I have a MDF riding mower. Last Summer I installed a 1/4 turn shut off valve in the gas line. I keep it off until I want to use the mower, then only open it 1/8th turn. When I'm done mowing, I turn it all the way off and let the mower die so I know the line is empty from it on down. Hope that helps.
Oct 27, 2009 | Mtd 22" Yard Machine Push Mower
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas flooding breather,cylinders and fills oil pan.
the needle in the carb is leaking by
you will need to remove the carb ad the float bowl and and check for somthiing in the needle and seat and check for damage and that the float moves freeley. then change your engine oil
turn your gas on and watch for leaks
Dec 01, 2008 | Craftsman 26 Hp 54" Deck Yard Tractor
Yard Machines 155 Torque Briggs  Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000 Logo
117 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
