Question about Viking DDB325SS Dishwasher
Viking dishwasher blinking pots pans normal cycle
Krazytech
  • 725 Answers
SOURCE: Viking dish washer won't drain
1) is the hose clear/ not kinked or pinched
2) is it hooked up to a garbage disposal..( was the plug removed)
3) can you hear something in the drain pump?
if all is good the let me know there may be more I can help with..
Posted on Aug 30, 2008
  • 82 Answers
Try clearing the air gap (which is the seemingly pointless thing that is near your kitchen faucet.)
1.Take off the shiny metal cover, and you can sometimes twist off the plastic cap, or you may need to use needle nose pliers to push in the tabs that hold it in. You may or may not see debris in the tube that is in the air-gap.
2. Now what you need to do is take a clear glass and put it over the air-gap with part of the glass hanging over the edge of the sink, you may want to put a towel around the other side of the glass to keep the water from going all over the counter, turn the dishwasher off then on again and select "rinse and hold". If there is any thing in the line it will come out.
3.If not you may need to take out the filter in the bottom of the dishwasher and on the left hand side in the sump area there is a small, (usually yellow) cap that covers the drain motor impeller that can usually be pulled towards the center/right by hand, if not with needle nose pliers. You will need to vacuum out the water with a wet/dry vacuum or towels.
If none of this works, let me know and I will go over some more uncommon draining problems.
Posted on Dec 08, 2008
  • 7 Answers
SOURCE: When I start the dishwasher it seems like the
Our problem, though for a different make and dishwasher, was solved by this link.http://www.appliancejournal.com/appliance-repair-help/dishwasher-repair-help/ge-dishwasher-repair/ge-dishwasher-motor-repair-problem-100/
Posted on May 05, 2010
SOURCE: Hi - my Viking dishwasher has developed a problem
if you open the kick plate, you'll see the pan below the motor and check for leaks. The leaks will trigger the sensor to pump water out. Once you dry out the pan, the pump motor will stop and you should be able to reset the program.
Posted on Oct 30, 2010
SOURCE: viking dishwasher has pan flood
ecomomy and normal wash lights blinking
Posted on May 15, 2011
My viking vdb325ss dishwasher runs for a few minutes and then stops with control pad lights blinking. The "normal cycle" and "pots and pans" lights blink together. I have reset and restarted the dis
Hello Peter!
Your owners manual or a call to Viking should help you decode the blinking panel lights. They are not random and are a desperate cry for help from the machine.
It has been my experience (YMMV) that a common dishwasher problem in older machines is accumulated grunge (the technical term) in the water level sensor. In many cases the sensor lives in a plastic container on the side of the DW and although the designers try hard to avoid contamination, the container eventually loads up and intermittently jams the float.
Before I pulled the unit however, I'd check the bottom of the wash cabinet for contaminants. There may be an screen (under a cover plate) that has clogged.
Your situation sounds a bit different, since my Samsung did not pump out water, it just stopped and flashed a code, but who knows? Go for the low-hanging, common issues first.
All the best.
Nov 23, 2014 | Viking VDB325SS Dishwasher
Viking DFB450 Tripping breaker in pots and Pans,normal, econo,cycle after prewash drains and fill. Heater or pump/motor bad? Does the pump have 2 speeds?
Dave,
You may have a bad breaker. Have you tried replacing the breaker? I would not think you heating element was bad unless it didn't heat up. If the pump works at all then the pump should be ok. If it does not work and you have power going to the pump motor then it may be causing a phase to ground resulting in the tripped breaker.
Oct 05, 2014 | Viking DFB450 Dishwasher
Pots/pans and normal wash cycle lights blinking fast and soak/scoure continuously lit and start light blinking slow all at the same time. Tried cutting power to reset, it didn't work.
Normally removing the power will clear this error code, if not the touch pad is bad. This is a simple repair, you can watch a video that explains how to repair this yourself at the link below.
http://www.appliancerepairlesson.com/
Mar 08, 2011 | Dishwashers
Hi - my Viking dishwasher has developed a problem where the pump runs continuously, whether the power switch is ON or OFF. After the power is turned ON, the troubleshooting guide indicates that there is...
Oct 15, 2010 | Viking DFUD042 Built-in Dishwasher
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Aug 09, 2009 | Kenmore 13743 Staimless Steel Built-in...
Cycle just continues with the pot symbol blinking
disconnect the hose and run it into a bucket, is it pumping freely?.
did you check the trap for a blockage?
You may have a leak in the pump housing area below the unit, this would cause the drain pump to run continually.
Jan 24, 2009 | Viking Designer Series DFUD041 (Premium)...
All 4 lights on my haier dishwasher Model CG206B blink and beep.
I had the same thing the drain hose was plugged.To reset You have to tilt the washer back 45 degrees.Mine is now running hope this helps.JIM
Jan 04, 2009 | Haier ESD200 Built-in Dishwasher
Aug 30, 2008 | Viking 24 in. Professional Series VUD040...
Viking DDB325SS Dishwasher Logo
598 people viewed this question
Top Viking Dishwashers Experts
Mike
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
