Question about Ricoh Aficio MP 2000 Black and White Copier
SC 500 error code on a Ricoh MP161
Getting error code SC500 on our Ricoh Aficio MP161. Checked for all possible opening and checked to make sure toner cartridge was in place. Turned off power and unplugged. No difference, error code still there.
  • 28 Answers
Main motor can turn that is why getting code. can be from photo conductor, to fuser or gear broke in back of copier. Will need tech for this one.
Posted on May 31, 2017
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 1035 sc code sc 329 troubleshooting
Laser diode beam not positioned correctly. Turn the machine off and back on and see if it goes away. You can run sp 2109-3 or 2109-4 in the service mode to adjust the beam in service mode by pressing on the yellow button. pressing the 107 keys and holding down on the clear button.
If this doesn't resolve the issue, you probably need a laser which we have one for sale here.
Posted on Dec 17, 2008
  • 126 Answers
SOURCE: sc 481 on my ricoh aficio 1224
moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Posted on Jan 08, 2009
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
What is SC500 error on Ricoh Aficio 2020D?
gear assy not turning can be many things. Main motor/devlp unit /fuser/ transfer roller
Aug 14, 2014 | Ricoh Aficio 2020 All-In-One Laser Printer
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Error code sc500
Main motor lock up could be the photoconductor unit or main motor or gear that runs off of it
Jan 27, 2014 | Ricoh Aficio MP 2000 Black and White...
My Ricoh 1018D is showing an sc500 error code. what could be wrong?
SC:500 Main motor lock
Symptom: A main motor lock signal is not detected for more than 7 consecutive
checks (700 ms) after the main motor starts to rotate, or the lock signal is not
detected for more than 7 consecutive checks during rotation after the last signal.
Possible Cause:
• Too much load on the drive mechanism
• Main motor defective
IMPORTANT: From my experience I tell you disassemble the image unit and check for worn gears. If not replace the main motor.
Feb 02, 2011 | Ricoh Aficio 2018 Copier
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
I have tried resetting ricoh aficio 161 showing error sc500, no luck , any offer of help appreciated
Main motor error SC 500 The main motor does not reach its operation speed within 0.7 second, or the main motor remains out of its operation speed for 0.7 second after reaching the operation speed. ?? Overload ?? Defective main motor
Apr 29, 2010 | Ricoh Aficio MP 2000 Black and White...
Eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
Apr 08, 2010 | Ricoh Aficio MP 2000 Black and White...
Aficio 2019d error code sc 500
iam asking for help to solve an error code SC500 on my photocopier machine DSm622
Mar 16, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio MP 2000 Black and White Copier Logo
388 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
