Question about Samsung SMH9187ST Microwave Oven
My Samsung microwave stopped working. Model SMH918ST. I replaced the fuses and that did not fix the problem.
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung Bio Ceramic Microwave lamp fused.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
You can order specific Samsung parts here.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Nov 09, 2008
No power to Samsung SMH7159 Microwave
There is more than one fuse. Look for a second one.
Aug 06, 2016 | Samsung Microwave Ovens
SAMSUNG MICROWAVE FAN STOPS WORKING. COULD IT JUST BE THE FUSE?
I would guess, I do not know for sure that the fa motor seized and blew the fuse, during the process the internal protection device on the fan motor opened giving you exactly what you are describing.
Nov 27, 2014 | Samsung Microwave Ovens
I have a samsung microwave model # smh1816s working fine all of sudden stop working no power is there a fuze if so where
They do have a fuse. They also have thermal cutoffs and possibly a thermal flame sensor fuse. the main fuse would be near the control panel the thermal flame sensor is usually near the back of the cavity usually on the left side on the outside of the cavity.
Nov 13, 2014 | Microwave Ovens
Samsung over the range microwave stopped working.
Please post a new help request and be sure to include the full model number from the tag on the unit as well as details on your symptoms, such as what it's doping or not doing, and when & how the problem occurs.
Then we'd be able to give you free help.
Dec 05, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Having an issue with the keypad - not responding
I would contact Samsung, they seem to be aware of the issue with the control panel failing on there otr model and are replacing them free of charge under there "epidemic warranty"
May 06, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Fuse on a Samsung smh918st
Unplug microwave oven, remove top, go to the keypad control board, follow wires to main circuit board, look for a silver rectangular capacitor, short across the two points with a screwdriver, look for a clipped in fuse near by, pop out and replace with the same current rating.
Mar 25, 2012 | Samsung SMH9187ST Microwave Oven
Kenmore 401.80082700 Over the range microwave just stopped working. WILL DO NOTHING! Is anyone home out there?
I would go ahead and replace the microwave oven the cost to repair will be higher than what you are thinking of getting.
Mar 23, 2012 | Kenmore Microwave Ovens
Where do I find the error codes?
if this is a counter top you should be able to remove the cover by removing the screws on the back, be aware that a lot of manufacturers use safety bits. about $24. once removed the tech sheet on top should have the codes and solutions
May 18, 2009 | Microwave Ovens
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Samsung SMH9187ST Microwave Oven Logo
69 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
