Question about Canon CLC 1150 Color Copier
RESET During transportation from dubai my copier had toner all over. after cleaning it comes on but it cant completely boot. No error ,the lcd is on but the writings are faded.
  • 76 Answers
I think your lcd disply exposed on the sun for long time
Posted on Dec 08, 2008
Toshiba model no 655 is coming and we clean toner huper and fix ;but cf 70 is still coming
From this very poorly worded question I glean that you are experiencing an error code of CF70 on your printer and you've attempted to solve it by cleaning the toner hopper.
This won't work, as the error code points to a problem with the toner transport motor.
I would get a printer technician to have a look.
Apr 01, 2015 | Toshiba Office Equipment & Supplies
E00013
Usually on canon copiers e 013 code means fool waste toner bottle.You probably have filled the screw which transports the waste toner into w. t. bottle.It's a pretty dirty work,so good luck wirh cleaning...
Aug 12, 2014 | Canon Office Equipment & Supplies
Error code E70 on ricoh FT 4418
Empty the waste toner tank.
1. Open the front cover
2. Lower the transport unit
3. Pinch the cleaning blade release lever and slide the cleaning unit out.
4. Remove the 4 screws in the top cover of the unit.
5. Dump out the waste toner.
Mar 14, 2011 | Ricoh FT5832 Copier
I AM GETTING ERROR ON STUDIO 520 IS CF70
[CF70] New toner transport motor abnormality (1) Check if the transport auger and paddle are not locked (no extraneous material or toner clod in
both the toner transport sections at the cleaner unit).
(2) Is the new toner transport motor disconnected?
(3) Check if the connector of the LGC board and connector Pins are not disconnected.
(4) Replace the new toner transport motor.
(5) Replace the LGC board.
-David.
Nov 03, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
Hi I have a samsung clx2160 printer out smudgy on colour
Please try to take out the imaging unit. Clean the area.
Donot touch with fingers. You ma use tissue paper. It may be due to spillage of toner during transportation etc.
Aug 01, 2009 | Office Equipment & Supplies
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Mar 09, 2009 | Toshiba E-STUDIO 550 Copier
Blank LCD display on Laserjet 3200
The LCD needs to be replaced. It is given an error code that you cant see.
Feb 11, 2009 | HP LaserJet 3200se Printer
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
Canon CLC 1150 Color Copier Logo
52 people viewed this question
old marine
old marine
