Question about Coby Audio Players & Recorders
It deleted songs from my mp3 but says there still there and it also says they are corrupted
    Master:
  • 763 Answers
Try to format it on your computer maybe it will solve your problem.
thank you for using fixya
CHARCOIS
Posted on Oct 27, 2008
How do i delete a corrupt file on our mp3 player, all itunes songs
Hi teresemolloy...
Here is an easy way to delete files:
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BIG WARNING: BE CAREFUL AND DO NOT DELET THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
This is a FREE answer, Please take time to rate me
May 18, 2011 | Jensen Audio Players & Recorders
I cannot delete songs from my Sansa e280. I have tried using both USB settings - MSC and MTP. When I try using "My Computer" it says it is deleting the files but they are still on the...
They are probably corrupt files. You will never be able to delete these unless you format your device, which unfortunately will delete all of your songs.
To format: Connect it to you computer, go to my computer, right click on Sansa and click on format. Once the format process has started don't interupt it. You will have to re-load all of your songs back on to the player, but at least your corrupt files will be deleted.
Mar 13, 2011 | SanDisk Sansa E280 MP3 Player
My memory card wont let me delete songs what can i do? the song i want to delete worked for two days ,then when i came to delete it , it said that the file is "corrupted" so everytime i try to delete , it...
SAVE YOUR CURRENT SONGS TO YOUR COMPUTER.THEN FORMAT YOUR MEMORY CARD.THEN COPY THE SONGS WHICH YOU WANT BACK TO THE PLAYER.DONT PUT THE CORRUPTED FILE BACK THIS TIME.HOPE THIS HELPS
Mar 06, 2010 | Coby MPC-848 MP3 Player
How do I delete songs or bad files? Is there any
The easiest way to delete songs or files on your Sansa is to connect it to your computer, open up "My Computer", double-click on the Sansa, then find the files inside the Sansa and delete them using Windows Explorer. Note that if these files are also on your computer's hard drive, and you're using a syncing tool (such as Windows Media Player) to sync songs from your computer to your Sansa, they may be copied back on your Sansa next time you sync, so you'll need to either delete or move the songs on your computer's hard drive, as well.
Whether you can repair a bad file depends on the contents of the file and the nature of the damage. If you believe that you have MP3s that are corrupted, there are utilities out there which will attempt to fix them. Google for "repair corrupted mp3" (or substitute "mp3" with whatever file type you're trying to repair) to find these utilities.
Feb 11, 2010 | SanDisk Sansa e260 MP3 Player
My sony mp3 player can't play my songs and the screen says 'file error'. how do i get over this problem? thank you so much.. =]
Hi, the songs files has been corrupted and need to be copied again into your mp3 player, i advice you delete the corrupt songs and re-copy the songs again on your mp3 player.
Compliments and wish you best of luck
Dec 25, 2009 | Sony NWZ-B103FBLK MP3 Player
RCA Pearl MP3 Player Major Problem!!!!!!!!!!!!!?
What I would recommend you to do is to plug in your device to your computer and format it..There might be some files that are corrupted..Formatting the device will delete all the songs you have in your device...After you format it, your problems should solve...
I hope that helps
Thank you
Mar 06, 2009 | RCA TH1101 MP3 Player
Rca 2763 fm corruppted file
There a few ways to handle a corrupted file. You can manually delete all the songs, and inspect the id3 tags to see if you can isolate the corrupt file (long and tedious approach). You can upgrade the firmware on the player, which will result in all songs being deleted, and missing files being revised/added in some cases (I would recommend this approach, but it is not a guaranteed fix). You could also format the player, which will delete all songs and resolve the corruption at least temporarily (but this carries a risk - you may end up deleting critical files, which may or may not be able to re-added later). The choice is yours - good luck!
-Tha Mp3 Doctor
Jun 18, 2008 | Audio Players & Recorders
Rca mp3
Three possibilities:
1) You did a firmware upgrade
2) You formatted the player
3) The DB became corrupt, and you will need to either reformat the player or upgrade the firmware
No, there is not a way to recover the deleted songs.
-Tha Mp3 Doctor
May 14, 2008 | RCA TH1101 MP3 Player
I need help!!!!!!
it may just be that certain song is corrupt and cant play you can try downloading the song again, but if it still does it the mp3 is probably faulty
May 10, 2008 | SanDisk Sansa E280 MP3 Player
Deleted songs
that's the problem with all MP3 players, when it's overcharged, it will corrupt the songs maybe because to malfuncion the system. The best solution is to redownload the songs that were lost OR if you have back up of those songs on your PC, much better..
trust me, I was experiencing on that before..
Feb 05, 2008 | SanDisk Sansa e250 MP3 Player
37 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
