Question about Epson Office Equipment & Supplies
E208 error after replacing the black dev unit
I've just replaced a black dev unit due to this E208 error message. After the replacement the eror came back. Is there a way to reset this error? The replacement was genuine and brand new. Thank you
5 Suggested Answers
SOURCE: Ricoh CL7000
go into the service mode and reset the count.
Posted on Aug 21, 2008
STARCOPY313
  • 5 Answers
SOURCE: Dev Home Sensor Error Replaced Imaging Unit and
TRY FIRMWARE
Posted on Sep 04, 2009
  • 87 Answers
SOURCE: Technical Black Imaging Unit Replaced,Error message still shows
Check out the details about this issue on my web site :
http://michelsplace
Posted on Mar 03, 2011
jas247
  • 844 Answers
SOURCE: I have a Ricoh CL7200
Welcome to FixYa.
I suspect that the gold contacts of the toner does not fit perfectly.
Remove the toner and wipe the gold contact with a clean cloth or cotton.
Make sure to install it back properly, close the latch properly as well.
Make sure that the toner has enough ink.
Turn of the printer.
Wait for 2 minutes and turn it back on.
Keep me posted.
Jas247
Posted on Apr 12, 2011
0025 error code
this is a common problem on this models
the motor is not turning
steps
first take out the dev unit and see if it has toner in it if the dev unit is full then check the sub hopper unit and if any one of these are empty then that motor is bad also verify if you are getting 24v at the motors that are driving the toner into the dev unit 2 motors located behind the primary charge unit cover
if 24v is missing then replace the pico fuse on the dc controller or replace the dc controller
if 24v is present then replace the motor
if you still need help contact me mickey at mnmsllc.com
Sep 11, 2012 | Canon Toner Cartridge For Cnm Ir 6570,...
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
What does code: DK means?. How can I fix it?
This code indicates that the Black Drum has reached 100k. It could also be the black developer and primary transfer belt are at 100k.
DC = Drum Cyan
DM = Drum Magenta
DY = D
rum Yellow
DK = Drum blacK
Even if it is reset you will still need the drum unit or drum/mc kit replaced very soon. These units do not last much longer than specified. After this the print quality deteriorates rapidly. Eventually the drum edges wear away so much that they can force developer out of the dev tank. You can usually get away with not replacing the K dev. If you reset the K dev at the same time as replacing the K drum unit, the machine adjusts itself can function normally. A dev normally lasts 200-300K. The primary belt unit lasts longer than the 100K spec and often beyond 200K out of them before replacement or refurbishment.
Finally, make sure that the Firmware is up to date.
Sep 30, 2009 | Sharp MX-3501N All-In-One Printer
Replace Color Dev. Unit (Type B) alert
You stated message said replace dev units. Why did you replace the PCU's? There is a difference. The color pcu's can go into any color slot but the deverloper units can only go in one slot. The dev units have a u shaped green plastic part on the front of them and just slide out. The pcus have a little lever and have to be released.
May 26, 2009 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio 3006 error sc452
The SC 326 is -- 2nd laser synchronization error. Meaning, the 2nd laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Basically your polygonal mirror motor unit is bad and needs to be replaced. You can replace the whole laser unit but that is expensive. When you replace the PMM unit, do so in a still air area -- as to not get anything in the unit. When you get the PMM unit -- contact me and I can walk you through the steps to replace.
The SC 452 is --- Transfer Belt Mark Detection Error. Once you fix the SC 326 error this one should be fixed also.
Jul 17, 2008 | Ricoh Aficio Colour 3006 Color Copier
Diagonal fading/banding???
hi, i had simular problem on a 3245 which is the copier version, fault was caused by the dev unit drive clutch sticking on and stripping the dev out of the unit. it would need replaceing t cure the problem
Jun 27, 2008 | Ricoh Aficio CL7200DL Laser Printer
Error Messages
The false Jam at MP E is a common error caused a manufacturing error/problem. You can download a solution to this problem HERE.
The K dev unit error can only be removed by replacing the dev and completing the service mode adjustments. A service manual will help you with this issue. Get one HERE.
Jun 06, 2008 | Epson Aculaser C1100 Printer
Ricoh CL7000
You NEED to REPLACE the black development unit with a BRAND NEW item......these things are chipped so it won't accept previously installed units.If the problem still exists try a new PCU (toner cartridge).
Apr 04, 2008 | Ricoh Aficio CL7000 Laser Printer
95 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
