Question about Kyocera FS-3900DN Laser Printer
Fs-3900 intermittently not printing
After this printer was physically moved it now usually fails to print unless it's powered off and on. It's networked with tcp/ip. firmware version is 2F9_3000.010.004 dated 8/aug/2007. Is there a later firmware and is installing it liable to help. If so do you know where I can get it. TIA.
  • dankieboy Oct 27, 2008
    sorry, ignore this. Have since discovered another printer on the network had beem erroneously given the same ip address.
  • 40 Answers
For FS-3900DN the latest firmware is the one what you have. BUT there is a separate update firmware for the Network Card !!
Check if you have installed the latest print driver in ALL computers and the OS updated with the latest patches.
Q1: The printing issue is consistent when you change computers ? IF yes THEN the issue is within the printer or the network.
Then:
Check if you have same issues when printing using the USB (not the network).
IF is printing OK when you use the USB but you got trouble using the network THEN something is wrong with the network printing so:
-> connect the printer straight to a PC/laptop using a crossover network cable that so you bypass the whole network (LAN) hardware.
--> IF is printing OK THEN the problem is within the network hardware(LAN) - you may try to pinpoint by replacing the network cable between the hub/router and the printer.
--> IF printing using the crossover cable is NOT OK then the problem is in the printer's network card. Check if the jack or the cable fit well into the printer or if the connector is not loose.
IF printing using USB is NOT OK then the problem may be into the printer. Reload the firmware engine and system + network card... it may help.
Q2: When you say: "fails to print unless it's powered OFF / ON" you mean the print job what you sent is waiting into the computer print spooler = the printer is being seen as NOT READY ? or the print job is just missing and you have to restart the printer and after that resend the print job ? ou can chack the printer stat by going to her IP address = open any internet browser and type the ip address. You should see a web page. Check the printer status before sending any print job.
Posted on Jan 10, 2009
Dark lines fs 3900
The lines are more than likely caused by either the Drum, Developer or Fuser unit. I have found in many cases that if non genuine toner is being used this will give you poor quality images. You can try using genuine toner which may resolve your issue but you may have to run a few hundred prints to clear out the old toner before the image improves.
Apr 15, 2014 | Kyocera FS-3900DN Laser Printer
Kyocera prints garbage
driver issue. download latest driver and update printer firmware
Feb 09, 2013 | Kyocera FS-920 Laser Printer
Error 5100
Error 5100 usually means a "General Error". In other words, the printer is not sure what is causing it to fail to print. This is usually a physical error, meaning the drivers are normal, your computer is normal, but something is failing inside the printer. Try turning the printer off and then on again. If it doesn't work, check if all the mechanical parts are moving. Sometimes, the rollers are stuck because of corrossion, or there are foreign materials that may have gotten through the printer that is preventing it from moving normally.
Apr 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Jan 19, 2011 | Kyocera FS-4000DN Laser Printer
Black dots printing on left side of paper
dots are usually always caused by the drum..drums are very easy to replace..(you don't even need a screwdriver)
here's how..
remove the unit that the toner sits into..it's called a process unit..comes out as a whole with the toners...
next open left cover..
remove waste toner bottle. (drum sits right above it!!!
next remove drum by pushing on grey button and pulling drum
out the left side of the printer.
as far as the jam message you might need to replace tray feed tires located up under the machine
Jan 11, 2010 | Kyocera FS-3900DN Laser Printer
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Prints strange characters
You will need to do a fimware upgrade on the machine.
Feb 12, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3900DN Laser Printer Logo
443 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
