Question about Dehumidifiers
I need instructions for a Micromark MM9088 dehumidifier
I think the switch which detects when the bucket is full may have been damaged when the bucket was inserted the wrong way round.
22yooper
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
  • 121 Answers
SOURCE: GE dehumidifier light says bucket is full but it isn't
Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
  • 52 Answers
SOURCE: Kenmore Dehumidifier Isn't Running
It sounds like you have power to the unit but a component is failing to start the system get an AC tech to check it.
Posted on Jun 09, 2009
heatman101
  • 43501 Answers
SOURCE: dehumidifier is saying bucket is full but it is empty
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 05, 2010
Flashing light is on(power on/off pad)
red lights on dehumidifiers almost always indicate a full water catch bucket , this does not allways mean it's actually full of water , the machine thinks it is , some thing has gone ary with the level sensor in bucket , these most times are a simple float switch, that can get knocked out of position when one is emptying the bucket , also this same float switch also allows machine to know there's a bucket in place to catch water , sometimes bucket is not in correct place to catch water so machine wont start
May 26, 2015 | Amana D945E 45 Pint Capacity Dehumidifier
Brand new ge 65 point dehumidifier seems to not be getting power I plug it in & nothing no lights no sound just nothing
if it's brand new i think you should return it to place of purchase , if not so new anymore , ck the water collection bucket it has a "Tipper" in it that detects a full bucket these are allways getting "out of wack!" and need to be adjusted slightly
Jan 05, 2015 | Dehumidifiers
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
Bucket full light on
I assume you mean it won't run and the bucket full light is on even when the bucket is not full. If this is your problem, I have it too. After hours of tearing my hair I *think* I know what the problem is. Playing with the "bucket full" microswitch I temporarily made the problem better.. but it went back to as bad as it was originally. I think it is a FAULTY BUCKET FULL MICROSWITCH. I use a hose anyway so I have no need for such a switch. Therefore, I will tear out the switch and short the leads together (or keep them isolated--- whichever corresponds to "not full"). I have a strong intuition this will do it. When I have time, I'll get it done and post the result, but you might want to try in the meantime and say what result was. Good luck.
Oct 07, 2012 | Kenmore 54501 Dehumidifier
Unit will not run as the "bucket full" switch
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
heatman101
Jun 05, 2011 | Comfort-Aire BHD-501 Dehumidifier
My Kenmore 580.54501 dehumidifier "Water Bucket
heatman101
May 27, 2011 | Kenmore 54501 Dehumidifier
Unit collects water but periodically continues running despite full bucket which is flush in unit, what could be causing this it doesn't happen everytime.
there is a floater switch on the machine over the bucket (and sometimes in it). the floater tells the machine that the bucket is full. if the floater is stuck, the machine will assume that the bucket is not yet full, and will continue to run. check that floater switch with the bucket out. you may need to press in the bucket switch so the machine thinks the bucket is in. then lift the floater and see if it stops running. if not, the switch is bad.
Jul 29, 2009 | LG LHD45EL Dehumidifier
Dehumidifiers Logo
502 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
