Question about HP PhotoSmart 7550 InkJet Printer
The print light is blinking red on my hp photosmart 7550
I keep getting the message paper jam, but as far as i can see all paper has been removed. When I feed the printer with paper, the paper goes through but doesn't print anything.
SOURCE: paper jam light is on
Guys .. the same problem again ... I solved it putting almost the full capacity of sheets into the paper feed, and when the print begins, push a little bit de hole package of sheets inside .... the printing should work just fine ... but ... it doesnt work for long docs, because, when the pile of sheets starts to became smaller, the problem cames back again .....
and for the record .. it is my last hp ... too.
Posted on Nov 04, 2007
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
ad74983.jpg Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
0e1481b.jpg and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
Posted on Feb 22, 2008
  • 32 Answers
SOURCE: Error LED blinking after paper jam, won't print
hi lorraine3 -
I hope you didn't 'throw it out the window!' just for a future quick ref, here are a couple fast links to hp support docs about paper jams and blinking lights that might help:
-paper jams
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00491031&dlc=en&product=501369
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00489775&dlc=en&product=501369
-blinking lights
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00496863&lc=en&dlc=en&cc=us&product=501369&rule=34731&lang=en
-JW50
Posted on Oct 08, 2008
mosesclive
  • 191 Answers
SOURCE: HP Photosmart 8250 Paper jam error
plz refer to the link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00386753&lc=en&dlc=en&cc=us&lang=en&rule=8662&product=443024
Posted on Dec 04, 2008
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Hp photosmart 7550 says carriage is stuck
print cartrigeis cradle is stuck clear jam then press ok in hp photosmart 7550.
Apr 04, 2009 | HP PhotoSmart 7550 InkJet Printer
HP Photosmart 7550 - Full Page Photo Printing Jams at end
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 17, 2009 | HP PhotoSmart 7550 InkJet Printer
Problem with HP 7450 and "Paper Jam"
hi, mezz
try this
There are 2 different types of flashing patterns with those two lights on the printer.
Resume light and power light BLINKING ALTERNATELY
Problem: Paper is jammed in the printer.
Resume blinking SIMULTANEOUSLY with power light
Problem:
The print cartridge carriage is stuck.
Solution:
1. Open the top of the printer.
2. Remove anything that is blocking the carriage path.
3. Turn the printer off.
4. Turn the printer on.
Problem:
There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
Solution:
If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
Unplug the power cord from the back of the printer.
Wait about 30 seconds.
Plug the power cord back into the wall outlet.
Plug the power cord to the back of the printer.
oke, post in me back
tq
cropp
Jan 24, 2008 | HP Photosmart 7450 InkJet Printer
Cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
7550 Cradle CRASHES!! into side of printer
I had the same problem with my 7550. I followed this shortcut and so far so good. Be real careful with the strip cleaning and don't use anything but a damp cloth. No solvents.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpd50646
Oct 29, 2007 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
