Question about Maytag MSD2432G Side by Side Refrigerator
I have msd2432gr- ice maker will not continue cycle to make ice, I have to restart freezer almost every morning and then it makes ice for 3-4 hours and then stops. What can I do?
  • 262 Answers
SOURCE: Ice maker problems
the heater on the ice maker has gone bad the easiest way to fix is to replace ice maker.the heater is on the bottom of the maker and heats tray up to harvest ice if it dont the ice will stick.But try taking maker out and cleaning it real good with a light spongee (Scrubee)
let it dry then spray some a light coat of pam (or similar) into ice bins and try that ahrd water will eat the coating off the bins
Posted on Jan 01, 2008
  • 1314 Answers
SOURCE: Maytag ice maker
ok first the dispencer doesnt affect ice production in any way onle diapencing so for get it the most common promblems will be the filter or the water valves on the back of the unit water and ice are on two different valves so because one works dont mean the other does also check the icemaker fill tube to see if its frozen a leaking icemaker water valve will cause it to freeze im also going to send you the procedure for checking the icemakermoudle its self do this after checking everything else remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Posted on Jul 22, 2008
SOURCE: Ice maker grinding sound
I had the same and found the same solution. Chances are the problem will come back. Just over a week ago (when it was freezing cold in Florida) I took everything out of the fridge and freezer, unplugged it, even pointed a hair dryer in the ice unit. Once I was done it was completely defrosted and dry. I have not heard anything since - and I can sleep again ;-).
Posted on Nov 05, 2008
  • 198 Answers
SOURCE: freezer working, not making ice; refrigerator not cooling
Look for excessive frost build up in the freezer, there may be a problem with the defrost cycle.
Posted on Jan 09, 2009
  • 31 Answers
SOURCE: maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Posted on Feb 07, 2009
I put a new filter in my fridaire, but water dispenser not working, and ice maker not working
repairs should be performed by a qualified repair person. when replacing a filter make sure the filter properly installed. once secured get 3,1 gallon containers to purge the water line and reservoir. BEWARE! water may continue to run while flushing the water line. this is why you'll need 3 containers. once you are able to finish flushing the line and the water is no longer gray the flushing for the water dispenser is complete. dispose the ice in the container in the freezer. let the ice maker cycle a few hours then dispose the filtered ice. once copleted you're done.
Jun 04, 2017 | Refrigerators
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
GE Refrigerator, ice melts in ice bin, Excessive heat on refrigerator side
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 09, 2012 | GE Refrigerators
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Does a Hoshizaki Model F-1001MWH have a Defrost cycle? As far as I know the "Defrost" is the harvest cycle correct?
flakers usually make ice continually. It utilizes an auger that rotates in a freezer barrel. It scraps the ice of the insides of the freezer barrel and forces it to the top and out. No harvest cycle is utilized.
Jun 10, 2010 | Hoshizaki F-1001M Flake Ice Maker
No water going to the ice maker
You could have either the ice maker causing this or the side of the water control valve that feeds the ice maker is defective. Here is a simple test to see which is causing the problem. Fill ice maker with tap water. If after the water freezes the cubes drop into the ice bin then the water does not refill it will need the dual water control valve replaced. If ice just sits there then the ice maker needs to be fixed or replaced depending on your Maytags model number. Let me know the model number and results, Thanks, Sea Breeze
Mar 18, 2010 | Maytag Refrigerators
Exactly the same.
The hose that carries the water from the top coil to the evaporator pan is plugged with ice. You need to leave your unit unplugged for a long time so the ice in the drain hose can melt. If you restart it too soon the problem will not be solved.
Jun 15, 2009 | Gladiator Freezerator Top Freezer...
Freezer working, not making ice; refrigerator not cooling
Dec 29, 2008 | Maytag MSD2756G Side by Side Refrigerator
Ice Maker water keeps running
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
Jul 13, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Maytag MSD2432G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
