Question about HP Photosmart C4280 Aio Printer
Paper jam can it be fixed?
My c4280 keeps saying paperjam, and i have opened up the printer and i see no paper whatsoever. I have tried turning it off and resetting it but it wont work. Any suggestions on how to fix this problem?
  • brimar126 Oct 27, 2008
    do i switch the setting of paper type to plain on the printer or from my pc? The printer wont allow me to do anything with the paperjam if i say ok it just goes back to paperjam and wont allow me to ise other options.
    Scholar:
  • 105 Answers
Hello brimar126,
To fix this issue, simply try setting the paper type to plain and then try printing. Hope this helps
gud luck
Posted on Oct 27, 2008
  • msmaniac Nov 05, 2008
    You need to set the paper type from the HP Solution Center or from the Printer properties in the Control Panel
My HP photosmart c4280 all in one printer is saying "out of paper" when it isn't out of paper.
Hello Jodi,
HP disagrees with your "NO rear door"... assessment...
For your reading pleasure I am attaching YOUR
OWNERS MANUAL... Page 15:
HP C4280 Photosmart All in One Color Inkjet Basic Manual Clear Paper Jams
Look at the picture.
Hope this helps.
Carnac the Magnificent
Aug 12, 2017 | HP Photosmart C4280 All-in-One InkJet...
Paper jam with my photosmart c4280 printer- help!!
Try this link...It may help.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00860153&product=3192753
As for the cartridge jam try resetting the printer. Open it up, make sure there is not jam. Move the carriage over if necessary, hit OK. Then turn the printer off. Go to your computer and remove any documents from the print queue. Then, with the computer still plugged into the printer, turn the printer on.
Mar 11, 2010 | HP Computers & Internet
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Turned it on and it says paper jam. There is no
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 22, 2009 | HP PhotoSmart C4280 Laser Printer
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
HP C4280 paper jam
there are a lot of paper sensor in it. i dont say buy new one , check sensors where they are and try to clean
Oct 10, 2009 | HP Photosmart C4280 Aio Printer
Paperjam
Check whether the inside is perfectly clean - it might be that while you were trying to fix the jam, some paper was left stuck inside. Otherwise try disconnecting the printer from the power supply to allow it to reset.
Sep 16, 2009 | Brother MFC 420CN All-In-One InkJet...
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
HP Photosmart C4280 Aio Printer Logo
550 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
