Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
MY SOUND PROBLEM
I HAVE A NEW BOARD THAT I FIX. EVERYTHING IS WORKING ALRIGHT. MY SOUND APPEARS TO BE OKAY WHEN CHECK. I HAVE ALL MY CONTROLS IN ORDER BUT I DON'T GET THE OUTPUT SO PLEASE HELP MY. MY ID IS isaacsongs@yahoo.com. hope i hear from you.
  • 4,924 Answers
Check if the drivers for the plugs are installed , it might been undetected on windows instalatin..or they might been disabled from sevices ...enable and run again the sound driver instalation
Posted on Feb 22, 2009
Treadmill SLT-02 flashs E1 and wont go. Everything else has been checked out and has a new belt and otherwise in good working order. How do I fix it
Please test the motor with the thermic switch inside of motor, for open or close, and repair. 2) Test the main motor with BATTERYR motor cicle 12Vdc, and see if the motor is running.
3) If everything is o.k the Controller motor board is faulty. replace LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 21, 2017 | Exercise & Fitness
Reebok RL 1500 elliptical lost all resistance
I had the same exact problem, and I mean the EXACT same problem. I also changed out the battery with no change. I contacted the generator company thinking it might be that, but they told me it could be the control board. I ordered a control board, changed it out, and now it works like new.
To sum up: Get a new control board.
Jun 19, 2012 | Reebok RL1500 Elliptical
I have a kenmore Ultra wash dishwasher Model # 665-16022400 apprx 7 yrs old-everything was working fine till xmas of 2011-then when you pushed smart wash then try to press start nothing happens-also you...
Well, Larry, it sounds as if you've tried just about everything.... except replacing the control console (with keypad), and if everything else is okay, then that is PROBABLY your problem.
Jan 09, 2012 | Kenmore Dishwashers
Temp Gage while on local streets seems okay. When I take it on freeway within. A few mnutes Gage is at. Red like its. Overheating. Although. Cars performance seems the same. Check under Hood radiator a...
sounds like the thermostat is staying closed or maybe a leak in one of the hoses id check it and if no loss of fluid and the antfreeze is topped off then id replace the thermostat see if fixes it make sure get the thermostat gasket too like 6 bucks for both
Sep 24, 2010 | 1993 Geo Metro
We push the start button and the power shuts off and unit won't start
There are some possible cause of the problem. It could be the fuse, loose wire, switch or the main control board.
You may take off the cover sheet and check if there are any loose wire connections. Next is to find the fuse and capacitor (usually has a marking of 10uF). If the fuse is blown or if the capacitor is pregnant, replace it and the washer should work again.
But if everything appeared to be okay, contact a local repair tech to take a look at your washer because you could have a bad control board. Defective control board should be replaced with a new one.
Thank you!
Feb 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Vision Fitness t8500 treadmill's deck just stopped working. It makes no noise when i turn it on. all other functions (elevations & programs) work fine. any troubleshooting ideas?
I had the same problem. I even ordered a $300 controller board. The new board didn't work either. That's when I started checking voltages from the control board to the motor. That was good. Lastly I checked the brushes. Almost nothing left. . . The motor started working again after I put everything back together. I need to order new brushes and return that contoller board.
Dec 28, 2009 | Exercise & Fitness
Maytag Gas Range Model #MGR 5745ADA will not pre-heat in a timely manner. The oven also does not reach temperature as indicated by the display. Could the ignitor be faulty?
Firstly do not attempt to fix or change any part, as this is gas related and requires a gas technician. It sounds like you may have an issue with your ignitor and you aren't reaching the correct temperature. Although you may still feel heat, this is from the ignitor. But in order to ignite the gas it must glow a WHITE hot and not orange. If it is orange it is faulty and will need to be replaced. part number for the ignitor is 12400035. and can be accessed safetly by removing the lower oven panel inside the ovens cavity. If your ignitor is okay and you are still getting gas inside the oven it will most likely be your control board. part number for the board is 74003800. I would have a technician diagnose it if everything appears okay.
Thanks
Oct 14, 2009 | Ovens
No picture no sound after a storm
check internal fuses on the power supply board --- sometime you can disconnect all cables and power and wait about one day -- re connect and everything works alright -- if this doesnt fix your problem -- you might replace the power supply board -- the bad part will be on the board and I dont anyone that repairs a single part - they replace the whole board
Mar 03, 2009 | Televison & Video
NO PICTURE OR NO SOUND it just black
power supply not working -- did you check internal fuses on board --? if everything checks alright - replace the power supply board
Mar 02, 2009 | Televison & Video
Hot water not entering washer, not a hose or solenoid problem...
Before ordering a new control board, check the wiring harness to make sure there are no breaks in the wire from the water valve to the board.  If everything checks out, replace the board.  The board is not that hard to replace and all the wire connectors are not confusing.
Aug 23, 2008 | LG WM2042 Front Load Washer
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
70 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
