Question about Kyocera FS Office Equipment & Supplies
Reset printer error 6000 kyocera fs 1016 - FS Kyocera Office Equipment & Supplies
  • 40 Answers
SOURCE: 6000 error on a Kyocera
a fuse it is blown within the FUSER UNIT - replace that fuse or call a technician to do it for you.
Posted on Jan 10, 2009
  • 300 Answers
SOURCE: CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
Posted on Apr 14, 2009
acdr
  • 1913 Answers
SOURCE: INSTALING KYOCERA FS-1016 PRINTER, COPIER AND SCANNER
download from this link.
http://www.kyoceramita.co.uk/index/products/download_centre.false.driver.FS1116MFP._.EN.html
Posted on Feb 11, 2009
Evildice
  • 217 Answers
SOURCE: Error code 6000:0106504
Fuser problem, you shall change fures termistor or lamp or both..Good Luck
Posted on Aug 14, 2009
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
Kyocera 1116 code 6000
Check the lamp and the thermostat for continuity. Check the operation of the thermistor. If something defective replace. Most common is the thermostat. In addition, check the operation of the cooler fan on the machine's left. If it is not working then you have to fix or replace it. The most rare but existing failure is call service 6000 due to defective power supply. In this case the heat roller is stuck on press roller.
Jun 03, 2014 | Kyocera FS-1016 Printer
Service error 6000
The service manual is located here: http://servicemode.ru/images/stories/files/kyosera_fs_1010_sm.pdf
Under section 6-16 you can find error (5) 6000.
It is a fuser unit error.
Jan 12, 2014 | Kyocera FS-1016 Printer
My Kyocera FS-1116 MFP says 'printer error'/'engine panic'.
If you get the Engine Panic error message, you need to turn the power switch off and then back on again. If that doesn't fix the error, contact a service representative to help resolve the problem.
Oct 17, 2011 | Kyocera FS-1016 Printer
Error de llamada 7980 en kyocera fs 1016 mfp
Mar 01, 2011 | Office Equipment & Supplies
Tengo una kyocera 1016 sale error call 6400 como elimino es problema por que nesecito solucion gracias
Code: 6400
Contents: Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB.
- Defective the engine/high voltage PWB.
Feb 09, 2011 | Kyocera FS-1016 Printer
Kyocera FS-1016MFP "printer error service
Code: 6000
Causes:
Feb 02, 2011 | Kyocera FS-1016 Printer
Kyocera fs 1016 mpf printer error service call 6400
Code: 6400
input within 3 s.
Causes:
Dec 15, 2010 | Kyocera FS-1016 Printer
Kyocera 1016 driver for Vista
I found the drivers on Australian Kyocera page ...
May 19, 2009 | Kyocera FS-1016 Printer
506 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
