I have an HD ready tv and have recently had a V box(Virginmedia fitted) the engineer could not test it at the time of fitting as computers were down.Although i am receiving cable station ok and the recording side is ok,I am unable to receive programmes that are broadcast in HD format and Virgin are blaming the tv.The tv is definately HD ready and has the correct terminals so any idea why I am not receiving it?
smeago1
  • 136 Answers
SOURCE: HDMI f/ dvd, dvr, receiver and tv
best set up if you have all hdmi is to have all your components go into the receiver ie. hd cable box, dvd etc. by using the hdmi output from the player(s) to the hdmi input to the receiver. next use one hdmi cable from the receiver to the tv then your laughing.
good luck
smeags
Posted on Dec 31, 2007
chrispurs1
  • 372 Answers
SOURCE: How do I get HD broadcasts on a Phillips 60PP9352 TV that's 'HD ready'?
Hi.
Im guessing your in the UK.
Asking about HD as you havent stated what country you are in.
Ok You will need the following to be able to watch HD pictures on your tv set.
Either Sky HD which involves having a dish fitted. Or Virgin cable system which is not available all over the country.
If you go to either of these systems you will need to pay a subscription to view the HD channels.
http://dysonmanuals.llc.nu/
Chris..
Posted on Jan 01, 2008
HossBud
  • 6 Answers
SOURCE: Screen Size
When you are using the DVI connection on this unit it will automatically set the aspect ratio. There is no way to force it into stretching the picture as it will with other input sources. The only way to get to fullscreen would be to go into the setup menu on your cable box and set the "4:3 override" option to one that will meet your satisfaction. I'm having issues with this one skewing the picture to the left on DVI input. I'll crack it open one of these days to see if there are some adjustments that I can mess with on the inside. If there is anything further I figure out, I'll repost.
Posted on Jan 02, 2008
SOURCE: Hannspree 32" LCD HD READY TV MODEL PRODUCT NO: JT01-32E2-OOOG
Just about every problem I have had has turned out to be relative to the scart sockets. (rolling screen, wrong colour etc).
May I suggest that someone moves the scart to see if it helps.
Rather obvious I know but the obvious often works.
B Hardie
Posted on Jan 08, 2008
  • 6 Answers
SOURCE: cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Posted on Jan 09, 2008
Connect hdmi
they are not HD ready so dont have the HDMI plug fitted. 3way models are fitted with HDMI
Jan 30, 2014 | Humax T800 TiVo 80-Hours Video Recorder
HD image doesn't fit in the screen.
Contact your cable operator and get the settings on Set top box adjusted. This will help you fit the image
Jan 01, 2014 | Samsung LN-T4071F 40 in. LCD HDTV
Colours are not fitting the picture
Look for any jammed buttons on remote. Remove battery from it. Switch off the TV manually, and wait for some time and switch it on. Now using control panel, try resetting it to what it was.
Aug 26, 2012 | Philips 37PF7320A 37 in. HD-Ready LCD...
My tv is about 6yrs old and says hd ready but the sky box hd cable does not fit where can i buy a hdmi lead to fit from
Without the specifics of make and model, I can only provide general guidelines here.
1) Being HD ready does not mean that the set hasan HDMI interface.
2) You should be able to connect the set using Component cables (Red/Green/Blue). These may be marked either RGB or YPrPb.
If you can update this with the available connectors on the cable box as well as the specifics of the TV, I should be able to give you more details.
Thanks,
Dan
Apr 20, 2011 | Televison & Video
How can I recieve hd channels i have just had a hd box fitted but there is nowhere to fit the hdmi cable to the tv
the cable or satellite box should also have a component input which is the red,white,red,blue and green cables.these will also provide hd quality
May 19, 2010 | Samsung SP43J6HD 43" Television
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Virginmedia v+ HD chipped box
Yes, you can get it working, if it to undergo repairs. Talk to a qualified technician.
Sep 21, 2009 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Dose my tv (Hisense TL3000) is hd-tv ready
Not all units were fitted with the DTV tuner before the switch over occurred. you set should have an insignia that sates that it is DTV ready. if this insignia is not on the box or actual set, you will need a converter box to receive this DTV signal.
Jun 21, 2009 | Hisense TL3000 30 in. HD-Ready LCD...
Digital TV not working
i had same probs tv 4 monts old new tuner fitted
and yet one more new tuner fitted when 8 months old
it now turns pick off at randod but sound stays on have to unplug mains for temp fix
now warranty has run out philips are not interested
Oct 31, 2007 | Philips 42PF9966 42 in. HD-Ready Plasma...
Screen Size
Oct 19, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
