Question about Dryers
Frigdaire Dryer I may have overloaded my Frigidaire dryer . It heats up but there is no movement.
    Genius:
  • 1,122 Answers
Sounds like your belt broke,you can pop the top with a puuty knife and remove the front to get to the belt,go to sears .com click on parts put in your model number and you can order your belt,hope this helps you-mike
Posted on Oct 27, 2008
Reason for door codes on a frigdaire front load dryer
Assuming door seal is good, make sure there is nothing "caught" under the seal that prevents the door from closing properly. Otherwise, look for anything else that would contribute to that issue. Possibly the door switch that turns on the interior light and acts as a safety for a door open situation may not be operating properly. See my "generic" tip for "buzzing" dryer issues.
Mar 03, 2015 | Frigidaire Affinity FAQE7011LW Electric...
Your door lock my be defective and need replacing. It has to send an input to the computer otherwise a door error will display
Replacing the power cord on a Frigdaire model FDE546RES1
if your new power cord had three prongs then you will hook up the white wire to the machine's white wire, red to red and black to black. if you have 4 prongs you will have extra green wire this will hook up to a ground screw
hope this helps
Jul 03, 2012 | Frigidaire Electric Dryer
Kenmore dryer will only work on no heat cycle...any other heat cycle will give pf code. md number 417.84092500
The Kenmore H5T is an electric clothes dryer meant for residential use and manufactured by the Kenmore Company, which manufactures a wide variety of appliances for the home, including refrigerators, dishwashers, microwaves, stoves, and clothes washers and dryers. While most Kenmore clothes dryers work well with only basic care and maintenance, certain problems, such as the dryer not heating, occasionally occur. Troubleshooting this issue may solve the problem without the help of a service technician.
instruction
  • Ensure that the dryer is properly connected to a working grounded power supply. Confirm that the power cord is plugged firmly into the dryer and the power outlet. Reset household fuses or circuit breakers if necessary.
  • 2 Remove the lint screen from the bottom front of the dryer. Pull off all lint so that the filter screen is clean, and replace the lint screen in the dryer.
  • Run the dryer for 5 minutes on a normal cycle and hold your hand under the outside exhaust hood to feel for air movement. If there is no air movement, turn off the dryer and unplug the unit. Disconnect the exhaust vent and clean out any possible obstructions, such as excess lint. Reconnect and confirm that the vent is not kinked or crushed and preventing proper heated air flow.
  • Ensure the dryer is not in a room or outside with ambient temperatures below 45 degrees Fahrenheit. The dryer will be unable to heat properly if the ambient temperature is too low.
  • Avoid overloading the dryer with too many clothes, which will limit proper heat and air flow in the dryer. Make sure the dryer is not set on an "Air Only" dry cycle, which does not provide heat.
  • Contact an authorized service technician if the preceding steps do not resolve the problem.
  • Dec 20, 2010 | Kenmore Dryers
    HEAT COMES ON & OFF ON DRYER TAKES 2 - 3 MORE TIME TO DRY CLOTHES. fRIGDAIRE GALLERY SERIES
    You have a blockage in the external connecting vent.
    Remove the vent and run a load.If it is dry in 60 minutes or less,repair the vent and remove the blockage.
    Jul 25, 2010 | Frigidaire Dryers
    Dyer no movement/heat on stack unit- washer fine
    It sounds like the dryer motor please change thanks
    rate me
    Apr 20, 2009 | Dryers
    Dryer keeps shutting off after few minutes.
    It sounds like to me that the timer may be bad. Does your breaker trip when this happens? If it does, then it is probably not the timer. The motor turning the drum might be going bad. It could be building up resistance then cutting it off on overload(current). Try to bypass the thermal overload switch which is located under the top. This may very well be your problem. Let me know how this does.
    Jan 28, 2009 | Frigidaire GLEQ642A Electric Dryer
    Frigidaire Dryer takes too long to dry.
    First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
    Jan 12, 2007 | Frigidaire GLER341A Electric Dryer
    Dryers Logo
    Top Dryers Experts
