Question about Sony Handycam DCR-DVD403 DVD Camcorder
LCD wont display when opened
My LCD screen will not display when i turn on camra, but it does work when i flip it around to 180 degrees. weird!?!? is it fixable?
  • 752 Answers
It's either a broken position switch or more likely a torn ribbon cable. It can be fixed by any competent dhop that services Sony cameras.
Posted on Mar 18, 2008
SOURCE:
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
Acer tablet troubleshooting
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
P c screen upsidedown
Hope this helps
Oct 20, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
Screen upside down
Holding down CTRL and ALT while pressing the DOWN ARROW flips the screen upside down.
To undo it, and flip it back to normal, hold down CTRL and ALT and press the UP ARROW.
You can also try CTRL-SHIFT and then “r” … this works for some Dell configurations
This problem can also be solve in some PC using the below technique.
In Control Panel>Display>Settings tab>Advanced button, look for settings relating to display or screen position.
Newer video cards have the capability to flip the display 90 and 180 degrees for use with LCD screens that can be rotated.
If the problem still persist, Start you PC with F8 key press, select "Last known good configuration that works"
it will most probably solve the problem.
Jan 20, 2010 | ASUS Eee PC 1000H Laptop
Screen has rotated 180 degrees
I have lots of Dell monitors and none of them has the ability to flip the screen orientation built into them. What I suspect has happened is he accidentally hit a keystroke combination that activated a feature in your video card driver. If you have the built-in Intel Extreme Graphics read this link and let us know if it helps. http://engtech.wordpress.com/2006/08/01/stupid-windows-features-monitor-display-turns-sideways-or-upside-down/
Dec 30, 2006 | Dell E173FPc 17" TFT LCD Flat Panel...
Sony Handycam DCR-DVD403 DVD Camcorder Logo
201 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
