Question about Refrigerators
How to defrost AEG Electrolux Santo - Refrigerators
5 Suggested Answers
  • 1462 Answers
SOURCE: I have an electrolux Aeg
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Posted on Oct 08, 2008
  • 1122 Answers
SOURCE: can I buy spare shelves
MAYBE,GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND SEE IF THEY HAVE YOUR PART,ALSO TRY REPAIR CLINIC.COM-MIKE
Posted on Dec 06, 2008
electrodynam
  • 35 Answers
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Posted on Mar 16, 2009
SOURCE: AEG Santo 1683-TK7 Led's and
as rwsummers correctly points out replace this part as from uk i bought it from maplins £3.31 part no N74CN 1UF 275V de-solder the two points on rear of pcb and re-solder new part in place and reassemble turn on power and "voila" works like new. Thanks.
Posted on Apr 10, 2010
My aeg santo fridge has ice build up on back panel
this is a defrost issue... you are going to have to defrost unit and check the heater and thermostat with a meter... if they check good I would check the pcb......................... hope this helped..........ken
Sep 30, 2014 | Refrigerators
I have an AEG Santo 72348 ka fridge that is supposed to be self defrosting. Mine regularly freezes up inside. Any help ?
Usually this is a symptom of a faulty door seal or a very frequently opened fridge they extra moisture load from the environmental air.
Feb 18, 2013 | AEG Refrigerators
Finding a refrigerater seal for an old aeg santo 1605
HI DAN.wow still going hain.well u'll be lucky to find one.i think yours is a screw on seal.try matching it to a universal fridge door seal.and cut to size.no other way.:) good luck.ali
Jul 04, 2012 | AEG Refrigerators
Defrosting
Switch thermostat to "0". Alternatively switch off, open doors and scrape excess ice off inside walls. Do not stab at the ice. Knock remaining frost off with blunt hammer or block of wood and scoop out with dustpan before switching back on
May 19, 2012 | AEG Santo 3888 KG8 Bottom Freezer...
AEG SANTO No_frost refrigerator beeps with 5 sec freqency
We have the same fridge, and I could not find my model either!
The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress the same button. That´s the quick fix.
To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG on http://www.electrolux-ui.com:8080
Feb 20, 2010 | AEG Santo 7085 KG Side by Side...
I have an electrolux Aeg santo fridge freezer. Frost free. There seems to be water leaking from the bottom.
Oct 08, 2008 | Electrolux Refrigerators
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
