Question about Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White
Replace washer caroma smartflush toilet - Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White
4 Suggested Answers
  • 6 Answers
SOURCE: how do I adjust the
By moving the float
Posted on Oct 25, 2010
  • 2841 Answers
SOURCE: hi, i have a caroma duel flush toilet possibly 10
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Posted on Jan 09, 2010
  • 1206 Answers
SOURCE: Caroma Sydney 305 toilet growls
this is caused by a slight leak in the wax ring causing a gurgle sound, remove it again and reset the wax ring should solve your problem. .
Posted on Jan 26, 2010
When toilet is flushed and refills water leaks into the cistern.
Are you saying that water is running into the toilet bowl? If so, check the rubber flapper at the bottom, and the valve (tube standing up).
Mar 29, 2016 | Caroma Home
Caroma 1991 need spare parts
All available replacement parts for Caroma Toilets can be purchased from this place. http://www.plumbingmall.com/Caroma-Spare-Parts/
They are a master distributors for Caroma here in the states.
Oct 04, 2014 | Caroma Home
Where can I buy Caroma outlet seals?
Take the existing part to Lowes or Home Depot and look at there universal
toilet replacement parts. I bet you can find one that will fit.
Jan 04, 2013 | Caroma CARAVELLE270ADAW-EL Caravelle...
Both of my Caroma toilets constantly "run",water is trickling constantly. How to stop those leaks? labels on toilets say: Caroma C Velle 305 EL SNV PAN made in PRC. Maintenance people from the...
Constant running can be due to a defective fill valve or faulty flapper. Try replacing either or both before discarding the entire toilet. One other possibility is that poor design results in poor operation.
Aug 07, 2017 | Caroma CARAVELLE270ADAW-EL Caravelle...
I have an old Caroma Dual flush ( 15-20 years) and the washers on the inlet valve dont seem to be able to regualate the flow in, after the toilet has been flushed, as a result water sprays up out of the...
Well luckly the velve can be replaced by a modern 1. iets not exspensive and dosent take long to do, u will get a step by step apon perches.
Plz rate my advice
Jun 16, 2010 | Caroma 270W-RF Reflection Round Front...
Jan 26, 2010 | Caroma toilet - water saving Sydney Low...
I have a 1998 Caroma Reflections cistern p/n 6871774. It is making a hissing noise after the tank is refilled, and water streaks down from the supply rim of the bowl. Which part needs to be replaced?
the inlet washer needs to be replaced to stop the overflow, the washers are easy to get and cheap but trying to get the unit open to replace the washer is my big question at the moment
Jan 10, 2010 | Caroma 270W-RF Reflection Round Front...
Hi, i have a caroma duel flush toilet possibly 10 years old, it is leaking into the bowl and then constantly re filling, i replaced the washer/ring/ thing at the point where the water exits into the bowl...
Jan 09, 2010 | Caroma 270W-RF Reflection Round Front...
Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White Logo
2,263 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
