Question about Zenith A27B41W TV
Zenith A27B41W I hae a zenith TV that went out. When I came into the room I knew right a way a component was fried, you know that smeel. I opened the case and right away I saw a few components that were burned. However I can not seem to find waht they are. On the PCB it has CX3231 next to the three components that were fried. I am assuming that this is the only problem. When you try to turn the TV on, it makes a buzzing noise no sound or picture. Please help! Thanks!
    President:
  • 3,130 Answers
I dont see this model number under PTS corp list of Zenith's modules. But a service manual is available from http://www.servicemanuals.net For a download. If you know how to work on solid state electronics, then you should have no problem with this repair. If your a handi person, a TV set is no place to be experimenting around inside of as it can seriously kill you. Find a trined tech to assist you with this. Good Luck
Posted on Aug 26, 2006
SOURCE:
I moved my zenith sentry 2 tv floor model from one room to another. when I first turned it on everything came on. there was a sizzling noise and everything went off and it has never came back on
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
Feb 28, 2015 | Zenith Televison & Video
Zenith a27b41w won't turn on. It just clicks whether using the remote or the button on the tv
Probably a power supply problem. The click could be a relay closing
Nov 04, 2012 | Televison & Video
The light above the power switch on my Zenith Z42PJ240 was blinking red. What does that mean?
means you have a fryed chip board in the tv, time to buy new, good luck
Dec 30, 2010 | Televison & Video
My zenith lcd tv has lost its blue tint. most
the light polarizer on the blue lcd panel is fried due to excesive dust and heat, and therefore need to be replaced. unfortunately, zenith may not sell individual parts of the optical engine, so you'll have to replace the whole optical engine.
Dec 17, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith tv dosen't work
Power supply Board Call UED 1-800-648-6657 or try Encompass 1-800-638-3328
Dec 07, 2009 | Zenith E44W46LCD 44" Rear Projection...
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
Looking for zenith remote code for TV/VCR combo
Zenith
101, 142, 149, 177
try these out and see if it works
Jan 31, 2009 | Televison & Video
Zenith replacement bulb
I would suggest to remove the lamp from your TV and check it. You can also just buy the lamp without the other hardware.
This site seems to have good prices.
Let me know if you need any more assistance.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
Junk TV & Poor service
zenith agreed today to replace mine.
Mar 12, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Color tint went out
replace the color ic have tech do that. checks should be made around the same ic for transistor leakage
Apr 07, 2007 | Zenith D32D51 32" TV
Televison & Video Logo
162 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
