Problems with Goodmans set top box GDB 12X12
Cant select chosen tv channel as channels just rotate in a loop or move on to say 20 channels away from the one you want.
jerryg50
  • 1689 Answers
SOURCE: Magnavox 15MF400T/37 Channel chosen is not correct channel
Check the instrucitons to verify if the channel table is pre-setable to designate your own numbers.
Most TV sets have an autoprogramming for the channels. Look in the menu for the auto programming and let the set re-program the channels if your set has that option. This feature will re-program the channals, and re-set their defaults.
If the channels are not able to be pre-setable to a custom table, then this indicates that there is a pre-scaling fault in the tuner or in the uPC. In this case, the set will need service.
Jerry G.
Posted on May 17, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
SOURCE: TV losing its channel memory
I had the same problem. I replaced the EEPROM marked U33 (it's a 24C32 in a smd package) and the TV worked fine.
BEFORE replacing the EEPROM you have to go into the Service Menu (hold down VOL- and CH+ on the local command) and take a note of all the values, specially the R,G,B gain and R,G,B bias, in the "standard" picture mode as well as in the "Cold" picture as well as in the "Warm" picture mode.
(if you forgot to do this, here are my default values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
then you put the "Cold" image mode and set again those values, increasing the G bias to about 300 and the B bias to about 310.
then put the "Warm" image mode and set again those values, increasing the R bias to about 300 and the G bias to about 280)
The other values such as brightness, contrast etc, have to be left at 50.
I hope this solution will FixYa!
Posted on Aug 06, 2008
SOURCE: I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Posted on Jun 26, 2009
  • 257 Answers
SOURCE: I cannot select Channel 10
What kind of antenna is used. Outdoor antenna or indoor antenna. The main board only detect the signal with certain level, if the signal strength is not enough, it will pass by. Since the change of signal from analog to digital this problem got more depending on your location. You need to use a booster-antenna to over come this problem.
Posted on Aug 18, 2009
Why cant i get my digital channels
Is your TV designed for digital signals, if not you will need a set top box. Make sure the aerial is in good order and all connections are tight and clean , go into settings on the TV, select digital tuning and press ok , if the TV is in good condition and there is a signal digital to the aerial it will download
Apr 19, 2015 | Element ELCHW402 40 in. LCD HDTV
I have lost the av channel and cant get it back
Not sure why you would need the AV channel. As long as the tv is switched on before the set-top box it should automatically show the video content as soon as the scart receives input.
I have not used the AV channel on any of my tv's since the digital switchover.
I am still using vhs tapes, a dvd player and a dvr top-box and use a multiway scart switch to select which to input to the tv scart.
Feb 20, 2015 | Televison & Video
Cant get ditical tv goodmans ld3355hd
hello martin, go into the dtv menu and select first time installation it should search for channel fingers crossed.
regardsshaun
May 11, 2012 | Goodmans GTVL19W17HVF LCD TV
It seems to forget its freeview channels and starts to run through every channel, interupting tv service provide by scart connection to talktalk box. First sympton is the sound volume icon appears on...
Tries tv and the box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The box to upgraded it softwares.Tv should be working again.If still have the same problems.Take ur tv backcover aparts and disconnection of the tv side manual control board PCB wire connection plug in that have like Power,Channel - +,Volme - + and Menu so on buttons switches.Turn the tv on and see if tv funtions correctly If yes than the tv manual cotrol buttons PCB board have to be change.If the manual contol board is diconnected from the tv Tuner signal board and have the same problems.Than ur tv have a bigger problems,the tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual control PCB board or the tv Tuner signal boards for the replacement.
Apr 07, 2011 | Samsung B2230HD LCD TV
I have the cobra 29 classic k40 antenna. The antenna light comes on when keyed up on 40 but only channel 40. I used an swr meter and that's as good as I can get. Is this ok?
Normally the swr should be set on the centre channel so if you have 40 channels you should set it on channel 20. This is because as you move away from channel 20 the swr rises slightly more for each channel away from the 20. If you set it on channel 40 you'll have twice as much swr on channel 1 more than if you set it on channel 20. If the swr metre shows 1:1 (i.e. doesn't move up at all) on channel 20 the rest should be ok since the antenna was designed for CB. You should however check that the needle showing reflected power doesn't go above 2.5
Jul 29, 2010 | Cobra 29 LTD CB Radio
Could you tell me why the tv insignia channels swich fron 2 to 3 channel, and the tv value is going up and down by itself? Because I"m not able to watch my programs. Can You help with this?
if you have set top box ,go to main menu ,check on restore factory settings ,put in default password 0000 and press ok,restarting the set top box automatically,waiting for some minutes.
restarting starts scanning all channels one by one and put them on their respective location in channel store.
now ,enjoy with all channels.
same process is done with tv if u have't any set top box ,only RF input from ur cable operator.
Nov 29, 2009 | Insignia IS 20" TV040919 TV
Cannot get my goodmans 289ns to accept the virgin digital signal
Will the TV go to channel 3? if not you need to reporogram the TV to sence channel 3 or go into the setup and undelete channel 3. Channel 3 is the channel your digital box is set to boradcast to the tv itself.
Apr 22, 2009 | Goodmans 289NS 14" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Sep 16, 2007 | Hitachi 51F710 Rear Projection Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
