Question about Siemens Gigaset S79H 8-Line Cordless Expansion Handset
Common Issues with Siemens Gigaset S79H 8-Line Cordless Expansion Handset - page 54
5 Suggested Answers
SOURCE: Gigaset 8800 PIN reset
  1. Turn the handset off by pressing and holding the PWR key.
  2. While holding down the keys 1, 4, and 7, turn the handset back on.
  3. It will display "Handset Service".
  4. While this message is displayed, type in the numbers 4 6 8 5 4 6 3 (the word "hotline") on the number pad.
  5. The phrase "Settings Reset to Default" for a second or two and the handset will power itself off.
Note: When you turn the handset back on, the handset PIN will be reset to 0000.
Posted on Jun 02, 2009
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
SOURCE: Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
Posted on Mar 06, 2010
  • 5102 Answers
SOURCE: My Siemens gigaset A 490
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
Posted on May 27, 2011
There is no caller identified
Contact your phone company and ask them to enable 'Caller Display'. Usually there is a charge for this service.
Jan 15, 2016 | Siemens S79H Gigaset Expansion Handset for...
How do I increase the number of times the phone rings?
I don't think u can, after 25 rings it usually goes to answer phone automatically, if its going to answer phone b4 that then turn answer phone off the automatic setting.
Apr 04, 2015 | Siemens S79H Gigaset Expansion Handset for...
Siemens Gigaset 4200 Cordless keep searching for base
The handset should be returned to the charging station, let it set for a few seconds. If this is a satellite phone, make sure the main phone "base unit" is connected to phone outlet and plugged in. After the phone has established its physical connection with the base again you can remove it and use it like normal.
May 18, 2012 | Siemens Gigaset 4200 Cordless Expansion...
PURCHASED USED SIEMANS 8800 HAND SET ,REPLACED BATTERY,AND RESET PIN TO DEFALT 0000, PHONE FLASHING "SEARCHING" .HOW DO I GET THE HAND SET TO SYNK UP TO THE BASE STATION?
You need to register the handset to your base to get the phone to work to do this follow the steps in the manual. If you do not have the manual go to the link below and scroll down to product detail then click on the blue product manual.
Gigaset-Accessory-Cordless/dp/B00005UFDR">http://www.amazon.com/Siemens-8800-Gigaset-Accessory-Cordless/dp/B00005UFDR
Or look below to learn how.
Jun 03, 2011 | Siemens Gigaset 8800 Cordless Expansion...
WON'T REGISTER TO THE BASE
Did you go to gigaset support site? Siemens had turned support over to a third party and most times can answer questions.
Mar 20, 2011 | Siemens Gigaset 8800 Cordless Expansion...
I cannot delete the messages in my answering system
http://download.gigaset.com/repository/1275/127598/A31008-M1801-A601-1-UZ19_17-11-2008_en_ARE.pdf
Above is your manual .If you go to page 11 this is the start of deleting messages.
Hope it helps!
Jan 02, 2010 | Siemens Gigaset 4000 Micro Cordless...
Handset won't work
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
Dec 26, 2008 | Siemens Gigaset 8800 Cordless Expansion...
Siemens Gigaset S79H 8-Line Cordless Expansion Handset Logo
1,403 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
