Question about Dryers
LG Condensing Dryer TD-C70040E drum not turning
  • 236 Answers
SOURCE: Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Posted on Feb 16, 2008
SOURCE: Clean filter light stays on LG TD-C70045E Dryer
I had the same problem. It actually has nothing to do with the filters. If your dryer sounds like it wants to start the capacitor is blown.
Posted on Jan 10, 2009
SOURCE: lg td-c70045e electric dryer power on but not turning
I had the same problem. Replaced the capacitor and now all is ok. Dryer is working 100%. If you hear a humming sound from the motor then it means the capcitor is faulty and does not start the motor properly.
SOURCE: LG TD-C70040E dryer shows ELE/EHE code ....
This happened to my LG dryer and I took of the raised back panel that covers the flywheel and there is a red reset button. This worked for me.
Good luck
Funny how this happened after 3 years exactly. hmmm
Posted on Dec 13, 2009
  • 1527 Answers
SOURCE: tumble dryer TD 4112 W has power but drum does not
hello the first thing to check is. the long pin on the inside of the door these sometimes snap off . if ok then check to see if the belt has come or snaped if ok then you may need to check the capacitor this next to the motor will have 2 wires coming off it these dry up good luck
regards
shaun
Posted on Jan 17, 2010
New drive belt on LG dryer to loose?
belt goes around drum the to the right of the tensioner and then to the motor pulley. you have to move the tensioner to the left to get the belt to the motor pulley. so the belt goes to the top of the tensioner, and around it in a clockwise manner, to the motor, not just under the motor and under the tensioner.
Sep 20, 2016 | LG Dryers
I am looking for a service manual for a Philips D153 Drum Dryer
This is a good site:
http://www.appliancerepair.net/dryer.htm
Hope it helped Tim
Oct 16, 2010 | Dryers
LG c70040e dryer not heating.
some there a reset button on the rear red give it press in wards and then try agin and see if it works
Feb 10, 2010 | LG Dryers
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
Good luck
Jun 14, 2009 | LG DLE5977 Electric Dryer
LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Jan 15, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG td-c70040e tumble dryer Clean Filter indicator will not go off
There is an access flap below the door on the bottom left.  Open the flap turn blue levers, take plastic cover off (there may be a bit of water there).  Clean the inside.  Problem solved
Nov 08, 2008 | LG Shine KE970 Cellular Phone
LG TD-C70045E Condensing Dryer does not heat up, how do I fix it? All other controlls work fine just no heat.
if not turn the power off and pull the dryer out and take the back off and push the red button in at the back
Aug 17, 2008 | LG Dryers
Lg tumble dryer td-c700453 all lights working just not drying clothes and drum turning round
turn the power off and pull the dryer out and take the back off and press the red button in at the back
Aug 06, 2008 | Dryers
Feb 16, 2008 | Dryers
Dryers Logo
53 people viewed this question
Top Dryers Experts
