Question about GE Hotpoint RA724KWH Kitchen Range
GE Hotpoint RB757WH1WW
My one year old oven clock is working fine but neither the burners nor the stove heat up at all. Since the clock is on, I know it is getting power so it is not a fuse. Any ideas on how to trouble shoot would be much appreciated.
    President:
  • 878 Answers
Sheila, this is a electric oven. It's possible that your missing one leg of power. On the back where the cord attaches (terminal block) you should have 240V across the two outside terminals and 120V from each end terminal to the center terminal. You will have to see if you have that voltage. The clock will operate itself on 120V but the elements need the 240V. Also check your breaker box and reset the breaker. Check this out first...Catriver..post back.
Posted on Aug 26, 2006
How to fix la germania burner?
Guess you mean a kitchen appliance not a cd/dvd burner! The only way to help you giving some advice about how to fix ut is if you tell us the problem you need to fix.
Describe your burner: is it a gas burner or an electric burner?
Had you repaired something similar before?
In any case, watch some youtube tutoriasl to repair a burner
Cooktop Range burner not heating burner light is on GE Hotpoint RCA...
GE Hotpoint RCA Gas Stove Repair Burner is not working JGSP44BEY3BB
Prego Project Fix GE Stove Burner
Stove Oven Range Burner Repair Diagnostic GE Hotpoint Kenmore Sears RCA...
Aug 19, 2015 | Computers & Internet
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint electic stove, the burners and the oven not working
Is there any sign of life? Does the oven light come on or does the clock work? Just for kicks, go and reset the breaker - it should be a double breaker for a 220V appliance - sometimes half will throw and still leave 110v that will run the light / clock.
Jul 26, 2009 | Hotpoint RB757 Electric Kitchen Range
Hotpoint stove with f3 code.
Replace the oven control module.It controls the bake and broil including clock and timer functions.
Jan 28, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
I need the wiring diagram for my Hotpoint stove. I need to know the color sequence for reconnecting them. Here is the model number...GE Hotpoint RB757WH1WW
Hi gilmore_lisa
Here is the Installation guide for your oven. The wiring diagram for connection plus step by step instructions start on page 39.
BE CAREFUL. MAINS ELECTRICITY CAN KILL
If you are unsure about anything... get an electrician to do this work for you. Thanks for using FixYa
regards
tobotek
May 08, 2008 | Kitchen Ranges
Kitchen Ranges Logo
328 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
