Question about Fisher and Paykel Washing Machines
Door latch front loader AWF 60 MD washing machine
Door closes but cycle wont start
  • 1294 Answers
SOURCE: Door can't be opened
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Posted on Sep 21, 2007
SOURCE: kenmore 417.29042992 front loader washer
If front loader washer quit spinning, check the wax motor switch. You can make a temporary fix by providing a short on the door lock contact. The Kenmore 417.29042992 front load washer provides a test connector that's readily accessible behind the front lower panel. Insert a wire between connector pins 1 and 2 (red and white/red color wires) and your washer should spin during the spin cycle. Hopes this helps.
Posted on Jan 28, 2008
Slinteriors
  • 8617 Answers
SOURCE: Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Posted on Mar 27, 2008
Coldcut
  • 1554 Answers
SOURCE: Frigidaire FWTr445rfs1 front loader - door closed but buzzes during washing
by the way it too fixya over 14 hrs to relay that message
Posted on Apr 16, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
Door wont close
This has to be a front loader - apparently the latching mechanism is not working and needs to be fixed. The machine will not operate when the door is not fully closed.
Jun 29, 2015 | Whirlpool Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Door wont open on Hotpoint WM51 First Edition
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
In your case you might have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Apr 25, 2013 | Washing Machines
My washing machine door is not opening at the end of a cycle. I put it onto another and it still won't at the end of that one. I've turned it off as well for 10 mins or so, and still nothing. Please help!
you didn't state whether it's a top or front loader. either way, there's a switch activated when the door is closed and washer is in cycle mode- so you can't open the door when a. the front loader has water in it, or b. the top loader is in agitate, or spin cycle. if top loader- there's a tab on the end opposite the hinge side that activates a switch that latches the cover closed when in 'dangerous' cycles (don't want to get your hand caught in the spin cycle!!). either a loose wire or a failed switch! prob. need to gently pop the top (should hinge back) to access the switch. UNPLUG THE WASHER!! if a a loose wire, re-attach-if not, replace switch! easy! good luck!
Apr 17, 2010 | Washing Machines
When I start my Bosch Axxis machine - I purchased it used - I do not hear the water start and the cycle isn't starting.
When you close door properly and press start does the door latch? If not possibly the latch is the problem. If it doesnt give a normally closed condition, the micro processor wont continue.
Sep 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
My washing machine works most of the time but sometimes i need to push the door really hard a few times to get the cycle to start. Today it broke down half way through cycle, got it going again then the...
Hi
Seems like the door switch is failing, or failed.
wpecially if a front loader, the door has to be closed, and register on the circuit as closed before the machine will start.
they are cheap and easy to replace, most of the time, but cant give instructions for an unknown whirlpool other than
take front panel off
replace door switch
replace front panel
Sep 21, 2008 | Whirlpool Washing Machines
Washing Machines Logo
112 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
