Question about Eaton Electrical Supplies
The test button on my 15amp eaton breaker does not reset when pushed
Nonplugs in our master bedroom work
  • 101 Answers
SOURCE: How do I reset a Eaton breaker with a tester on
This is a GFI (Ground Circuit Interrupter) Breaker. So you need to turn off the circuit breaker first. Then you need to reset the GFI (yellow button) by pressing in the button. And then turning the breaker back on. Now, with some GFI's, you need power on to reset them. So if this is the case, reset the circuit breaker by turning it off and then back on. Then press the yellow button in, and it should hold. Then you should have power restored. I hope this works for you. If not, feel free to contact me again. Good Luck!
Posted on Mar 30, 2010
VtToolMan
  • 704 Answers
SOURCE: pushmatic 15amp breaker was buzzing. I turned it
I'd be careful with any BullDog or Pushmatic breakers. They ceased manufacturing these years ago due to problems with the contactors inside the breaker being prone to arcing and sticking (becoming "welded" together). UL and other agencies deemed them unreliable and the company decided to cease production due to several problems with installations of their products and the growing safety concerns.
If you can get a replacement breaker, I would seriously consider replacing it when you can. Otherwise, keep an eye on it, since this might fail while in the "on" position and if the contacts continue to arc, (that's symptomatic of the buzzing sound you heard), it's possible that the contacts could become "welded" together and the breaker won't trip in an overloaded circuit condition and potentially cause damage to whatever is on that circuit up to and including a situation for having a fire potential.
There is a company that is making replacement breakers under the same tradename and they are using different manufacturing techniques so as to not have the types of problems the original design could cause. Usually you can find them at most electrical supply houses and at True Value stores, depending where in the country you're located.
Hope you found this helpful and best regards!
Posted on Aug 06, 2009
  • 66 Answers
If the lever is in the middle position, you will need to move it all the way to the off position, (towards the outside of the panel) and then back to the on position (towards the middle of the panel) If it trips again, try to turn all of the light switches of that circuit to the "off" position and try again. the arc fault breakers are designed to sense loose connections in outlets, light switches and lights. by turning the light switches off it will give you a chance to find out which sets of lights may be causing the problem. keep in mind that it could be a total accumulation of the lights (total amp draw) so if it resets and then trips, try turning on the lights in a different order.
Posted on May 22, 2010
berndog
SOURCE: Eaton Arc Fault Breaker type BRAF tripped.
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
Posted on Sep 03, 2010
  • 66 Answers
SOURCE: Cutler Hammer 20 Arc Fault
The circuit breaker must be turned to the "off" position first from the middle position, and then to the "on" position. The cutler hammer arc breakers carry a lifetime warranty so if it will not reset you may want to contact the manufacture.
Posted on Oct 26, 2010
The test button on my 15 amp eaton breaker does not reset when pushed.
spring inside has come off, or their is no power going to it.
Feb 25, 2015 | Eaton Electrical Supplies
Tandem Breakers
The use of 2 15amp breakers first had meaning. If you can relocate with one tandem 15 amp it means that there will be no protection cuase the tandem tripping point does not count.
Feb 12, 2014 | Eaton Corporation BR4040B200 Main Breaker...
15amp Eaton Arc fault breaker type BRAF trips every day at same time. There are no high amp electrical things plugged in. What is causing this? should I have it replaced?
"Arc fault" breakers trip when an arc occurs, either in a receptacle or a light switch, for example. An arc can be caused by an old light switch, when turning it on. An arc can also occur when you unplug a chord while the device is still turned on or running.
Aug 25, 2013 | Eaton ARC FAULT CIRC BREAKER
How do I reset a Eaton breaker with a tester on it?
Mar 27, 2010 | Eaton 20A ARC FAULT BREAKER
Half of the appliances and outlets quit working when hot water tripped . we reset then next day the lights went out in my bedroom (master) the kitchen and the stove as well as the AC no longer work . where...
Go to your electrical panel and check your circuit breakers. You can check each one by turning each breaker off - then back on again. You should get back some of your electricity. Also, you probably have a GFI circuit breaker located in your kitchen (near the sink) and in your bathroom's (near the sink/basin). Make sure to push in the reset button (make sure it holds when you press it in). This will explain why you have some receptacles that are out in other parts of your house.  Why receptacles are wired through GFI's, etc... are to provide extra grounding protection. I hope this works for you. If not, feel free to contact me again with more information. Good Luck to you!
Mar 18, 2010 | Siemens #MP120GF 20A SP GFI Breaker
Eaton Arc Fault Breaker type BRAF tripped. I reset it but lights will not work. Ideas please?
Feb 19, 2010 | Eaton ARC FAULT CIRC BREAKER
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
During heavy lightning, our home temporarily lost power. all power restored except for the master bedroom circuit which would not reset. is this a simple fix or will it require an electrician?
If this is the only circuit not resetting, and no other section of the home is on this circuit, it is possible that the circuit is defective due to the storm or sometype nof overload on that circuit. However, if you remove the circuit, look at the bus where the breaker was attached and see if it is pitted. Also check if the breaker is fitting securely and not moving. If this does not solve the problem, there is possibly a wire that has come apart, in which case the circuit has to be traced from the panel to the master bedroom.
You should have power in the room however, as the overhead lighting and the outlet circuit around the wall is usually separated. So there shoulde be some power in the room. If not more than one circuit is out and in which case you may have to enlist an electrician.
Hope this have helped you with your problem.
May 17, 2009 | Cutler Hammer Eaton Electical #BD3030...
Electrical Supplies Logo
734 people viewed this question
Top Eaton Electrical Supplies Experts
john h
T-Comtech Repairs
T-Comtech Repairs
Are you an Eaton Electrical Supply Expert? Answer questions, earn points and help others
