Question about AEG Refrigerators
AEG Santo 3688-6KA clicking noise
My Santo has developed a nasty clicking noise when it tries to start. As far as understand this fridge does not have a normal starter relay and the noise comes from the control panel in the upper part of the fridge and not from the compressor area. Any idea of what could be wrong?
  • markyyork May 11, 2010
    MY FRIDGE 3688 6KA HAS STARTED MAKING A CONTINUOUS BEEPING NOIS. ANY IDEAS O WHAT IT COULD BE?
3 Suggested Answers
kweaver1
  • 3 Answers
SOURCE: AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Posted on Jan 20, 2008
KikkaMikko
SOURCE: AEG Santo Fridge light flashing
Here is fix photos:
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
Posted on Aug 11, 2008
Aeg santo fridge keeps freezing
Fixya will not let me post links today, or their "capcha" thing does not seem to be working properly, so I will have to try this another way.
I've done some research on your issue and it seems that should only happen if the temperature sensor goes bad, or the evaporator sensor. Each of the two parts cost less than 30 pounds each, so may be less expensive than tossing out the whole thing.
Try browsing to shop (dot) aeg (dot) co (dot) uk
Then in the search at the top right, type in "santo" and look for the two sensors and decide if it would be worth a try.
Oct 14, 2013 | Refrigerators
Finding a refrigerater seal for an old aeg santo 1605
HI DAN.wow still going hain.well u'll be lucky to find one.i think yours is a screw on seal.try matching it to a universal fridge door seal.and cut to size.no other way.:) good luck.ali
Jul 04, 2012 | AEG Refrigerators
AEG SANTO No_frost refrigerator beeps with 5 sec freqency
We have the same fridge, and I could not find my model either!
The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress the same button. That´s the quick fix.
To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG on http://www.electrolux-ui.com:8080
Feb 20, 2010 | AEG Santo 7085 KG Side by Side...
My aeg santo 70168 has a puddle of water at the bottom every few days.
if the water is inside check the drain on the back of the fridge if it is on the floor make sure the drain hose is in the drsin pan
Dec 07, 2009 | AEG Santo U 86000i Compact Refrigerator
Can I buy spare shelves for an AEG santo 3790-6 KG fridge/freezer
MAYBE,GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND SEE IF THEY HAVE YOUR PART,ALSO TRY REPAIR CLINIC.COM-MIKE
Dec 06, 2008 | AEG S70408KG Bottom Freezer Refrigerator
AEG Santo
here is a link where you can download an english version http://www.nodevice.com/user_manual/aeg/refrigeration_1192865302/santo_3442_kg_glassline_621672048.html
you will need adobe reader to be able to read it, you can also download it for free. if this helped you then please leave feed back,cheers.
Feb 24, 2008 | AEG Santo 3888 KG8 Bottom Freezer...
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
What does the flashing (warning?) light mean
Did you ever get any advice for this problem? Please repost if not.
Oct 22, 2006 | AEG Santo 3888 KG8 Bottom Freezer...
Refrigerators Logo
179 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
ashburton
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
