Question about Microsoft Windows XP Home Edition
Unable to load sqlboot.dll
SQL Server installation is either corrupt or has been tampered with (Unable to load SQLBOOT.DLL
  • 91 Answers
SOURCE: unable to add local server with SQL-Server Management Studio 2005
ok, you installed the management studio but did you install SQL server?
That is not part of the management product.
Posted on Jan 05, 2009
kd24911
  • 90 Answers
SOURCE: i am unable to install sql server 2005 in windows
You can download Windows Server 2003 (SP2) from following link:
http://www.microsoft.com/downloads/details.aspx?FamilyID=95ac1610-c232-4644-b828-c55eec605d55&displaylang=en
Thanks.
Posted on Mar 18, 2009
Squirm57
  • 152 Answers
SOURCE: my computer is very very slow at starting & at
Go to this site and you can repair or download your missing DLL files
Posted on Mar 21, 2009
proton77
  • 1183 Answers
SOURCE: xolehlp.dll problen
You can go to the following link and download the file
http://www.dll-files.com/dllindex/dll-files.shtml?xolehlp
1. save the file on the desktop
2. Right click on the saved file and extract it the following location
c:windows/system32
3. Restart your computer and try installing sql again
Best of Luck
Proton
Posted on Apr 12, 2009
  • 187 Answers
SOURCE: i cant download anything on my pc
winssnotify.exe is a program that is associated with windows "One Care." Unless you specified otherwise, you should see the One Care icon near running programs (area near the clock, on the bottom right of your screen). Go to Control Panel, uninstall/install programs and Reinstall or repair One Care. One Care is legit, and has firewall/virus options associated with it. If you recently uninstalled the program or installed another antivirus program, that may be your issue. If you uninstalled it, there may be files that were not removed or another program may have identified Onecare files as spyware. If you recently did anything like a "registry cleaner" or supposed "scan" of your system from a less than reputable online source, that can definitely be your issue. If you never downloaded Onecare, the program may be an imposter. It should be located under program files in the one care folder. If you do have this program, Onecare has a website scan to help users with problems. Hope this helps. Leave a comment if you need further assistance.
Posted on Nov 17, 2009
Testimonial: "it was helpful to a degree but i dont have onecare on the pc, and i have tried numerous webpages, but im unable to download anything what so ever "
Better and safe way to repair and recover MDF files
To choose a reliable and 100% safe and secure, a SQL server database recovery utility guarantee the zero loss of quality. You can refer to this page: http://www.sqlrecovery.org and also read this post http://recoverymaster.livejournal.com/519.html
Jun 04, 2014 | Microsoft SQL Server 2000 Standard Edition...
1670: unable to load module d:\iss setup.dll,error code:193
get current PS update when you turn on system - if the update doesn't automatically load - go to system - system updates - follow instructions on machine.
Jun 22, 2013 | Activision Spiderman: Friend or Foe for...
Ved opstart af window defender
From your description, I understand the issue to be: you received VSS error 0x8007042d.
I. First please re-registry the following DLLs to see if it helps:
1. Stop the Volume Shadow Copy service: Open a command prompt and change
directories to \WINDOWS\system32 (this is important when you begin
registering the DLLs):
net stop vss
2. Then register the following DLLs and services (be sure you're still in
the WINDOWS\system32 directory at your command prompt):
regsvr32 ole32.dll
regsvr32 vss_ps.dll
Vssvc /Register
regsvr32 /i swprv.dll
regsvr32 /i eventcls.dll
regsvr32 es.dll
regsvr32 stdprov.dll
regsvr32 vssui.dll
regsvr32 msxml.dll
regsvr32 msxml3.dll
regsvr32 msxml4.dll
Start the Volume Shadow Copy service by running "net start vss", do a test
backup and see how it goes.
II. If the issue persists, Let's perform these troubleshooting steps:
1. Make sure you can use OSQL to connect to every running instance of
SQL/MSDE on the box, if you can not disable all of the instances.
You can find all of the instances installed on your server, by looking at
this registry value: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL
Server\InstalledInstances
The syntax would be "OSQL -E -S <servername>\<instancename>
For example OSQL -E -S server\SharePoint
If you can't connect to the database, then it will cause this type of
failure.
Also make sure that each of the SQL/MSDE instances is either running under
the Local System account or a Domain Admin account.
2. The issue may occur if there is corrupted data on the drive to be backed
up. Please run CHKDSK on each drive with the /f switch to fix the errors on
the disk (if there are any).
3. Per my experience, this issue can be due to VSS thinks the system is
still in setup process. Please perform the steps below to check the status.
WARNING: Using Registry Editor incorrectly can cause serious problems that
may require you to reinstall Windows. Microsoft cannot guarantee that
problems resulting from the incorrect use of Registry Editor can be solved.
Use Registry Editor at your own risk.
Open the registry and locate the registry key:
HKEY_LOCAL_MACHINE\SYSTEM\Setup
Ensure both registry values are set to 0:
- SystemSetupInProgress
- UpgradeInProgress
4. If the issue still happens, reinstall COM+ by following these steps:
A. Backup and then delete HKLM\Software\Microsoft\COM3
B. Boot to Recovery console and rename clbcatq.dll to ~clbcatq.dll. Be sure
to use the tilde.
C. Boot to normal mode and in Control Panel, open the Add or Remove
Programs tool, and then open the Add/Remove Windows Components tool. Do not
make any changes, just click "Next". This reinstalls COM+.
NOTE: You must have your Windows Server 2003 SP1 files available during
this step.
Hope above information helps! I am happy to be of assistance to you and
look forward to your reply!
May 31, 2010 | Microsoft Windows Vista Ultimate Edition
Window itunes.exe-unable to locate component. box
hey, dll is a file in your pc, try to look for a qtcf.dll in the internet then try to download it,else try to re install your itunes, but use other installer, maybe the installer is corrupted.
Sep 30, 2009 | Audio Players & Recorders
Money was unable to load the registration
It looks like the Microsoft Money installation may have been corrupted by the installation (or removal) of another application.
You could try the following:
  1. Copy the following files from the installation CD to the MNYCoreFiles folder on your computer:
    - eularegn.dll
    - wkernlng.dll
  2. [OR] Reinstall Microsoft Money. MNYCoreFiles
Aug 19, 2009 | Microsoft Money 2007 Home & Business for...
When installing I receive an error message "Unable to open serial number file". After the install, if I try to open the application I receive the error "Unable to find serial number. Please make sure the...
To all that run into this problem like I have, here is the solution:
To install Suretrak 3.0 if you get “unable to find serial#” error:
  1. Temporarily Stop the Pervasive Sql Server Workgroup engine
  2. Install Suretrak
  3. After installation, copy wbtrcall.dll and wbtrv32.dll from the c:\pvsw\bin folder and paste to c:\windows\system and c:\windows\system32
Restart computer; all should be working now
Adrian (byrdadrian@yahoo.com)
Jul 24, 2009 | Primavera SureTrak Project Manager 3.0 for...
Xolehlp.dll problen
c:windows/system32
Best of Luck
Proton
Apr 12, 2009 | Microsoft Windows Vista Ultimate Edition
Unable to load vopyl.dll
can play alexander unable to load voplyl.dll library
Mar 29, 2009 | Ubi Soft Entertainment Alexander
Cant install a printer
HP PSC 1410 All-In-One InkJet Printer installation
Sep 22, 2008 | HP PSC 1410 All-In-One InkJet Printer
QUEST SQL Navigator 3.2 with Oracle 10g Fails
I followed the advice given above and copied the ORACLE_HOME/bin/ociw32.dll to ora73.dll in the same directory. copy ociw32.dll ora73.dll
And the software worked immediately.
Dec 21, 2006 | Quest Software SQL Navigator Professional...
Microsoft Windows XP Home Edition Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
