Question about Sharp Aquos Televison & Video
Green line through Sharp LED tv
A vertical thin green line running down the right side of my 60 in. How to fix?
SOURCE: green vertical line on the right side of screen
I bumped my screen by accident recently and now have a similar problem (multiple vertical and horizontal thin lines). I was told that the screen is now bad and probably cannot be repaired. The cost of replacement is more than the cost of a new set. Sorry, but that may not be the answer that you are looking for.
Posted on Dec 10, 2007
freetek
  • 5568 Answers
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Posted on Jul 09, 2008
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Posted on Sep 28, 2008
  • 586 Answers
SOURCE: Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Posted on Jun 27, 2009
roety
  • 585 Answers
SOURCE: thin green vertical line on right side of tv
if the line is on all inputs and in the menu too the panel is bad (not a repairable item, cost wise)
Posted on Aug 01, 2009
Sharp Aquos LC60LE632U 60" TV 1080p. LCD HDTV. Great picture. Except, there is one green line, running vertical down the far right of the screen. I'm suspecting that it may be the TCON Board.
I had a similar problem with my Sharp Aquos 60" LED and it was the T-Con Board. Simple to replace and can be purchased in the neighborhood of 40.00. If you have sound and a picture, T-Con Board replacement should be your fix. Great videos on youtube if you need assistance. I would highly recommend that you watch the videos prior to proceeding. I am NOT a TV repairman, just a do-it-your-selfer....
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Mar 31, 2016 | Sharp Televison & Video
How to fix green vertical line on 60" vizio led smart tv
I had a similiar problem on a Sony , vertical line or lines on the left side of the screen. It was the driver board for the LCD. Good Luck
Mar 17, 2014 | Televison & Video
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Thin green vertical line on the lft side of LCD TV
redone all connector inside of the tv
like those flat wire you have to check allthose flat and clean and redonne try that
Oct 14, 2009 | Televison & Video
Line down the middle of my sharp aquos 42 inch
first make sure it does not come from the signal. If its really from the tv and look like a darker line it can come from the lcd control unit but most of the time its a dfective lcd panel
Mar 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green vertical line on the right side of screen
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
Nov 26, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
799 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
