Question about Amana Refrigerators
Amana ARS2663AW Side by Side Refrigerator
Manual
aborcass
  • 2651 Answers
SOURCE: Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Posted on Feb 19, 2009
jan mczeal
  • 632 Answers
SOURCE: AMANA REFRIGERATOR SIDE BY SIDE IS NOT COOLING MODEL 36531
Check/do the following:
Note: You may need the service of a qualified technician to do the job. The compressor and condenser are not user serviceable.
  1. Check for any open or burnt wiring and rewire if necessary.
  2. Check fuses and circuit breakers.
  3. Check and reset overload relay.
  4. Turn the thermostat knob to the proper setting.
  5. Pullout the capacitor and check it. Using an ohmmeter, connect the test leads to the capacitor terminals. Do the same with the test leads in reverse.The pointer must deflect to the right and smoothly moves back to the left. Otherwise capacitor is defective. Replace it with the same specifications.
  6. If compressor and capacitor is found okay, check for open thermostat. Unplug the unit and connect test leads of ohmmeter to the plug terminals. Turn the thermostat knob. The ohmmeter pointer must deflect, otherwise replace thermostat.
  7. If all of the showed no problem then you probably have a low refrigerant in your unit. Check for any leak and recharge.
Posted on Sep 04, 2009
arikrom
  • 528 Answers
SOURCE: Amana side by side. Freezer is working. Refrigerator isn't'!
  1. take all from freezer side out
  2. open back wall
  3. check if the fan is damage
  4. check the heater element
  5. check thermostat
  6. one of them is bad
  7. good luck
Posted on Jan 02, 2010
Sheikhtijani
  • 1284 Answers
SOURCE: Proper refrigerant levels for Amana Side by Side refrigerator
Hi, normally the suction pressure on a refrigerant -22 system will be between 60 pounds gauge pressure (which keeps it above freezing point) and about 80 pounds. This depends on the temperature condition.Make sure that the superheat and subcooling are correct to see what is to be considered normal for the conditions you have present.
Take care
Posted on Jun 03, 2010
SOURCE: Amana ARS2464B Side by Side
repairclinic.com has all parts for this fridge.
Posted on Jul 09, 2011
We never received a manual and now need to replace the water filter. model no. ASD2522WRW03 - ser. no. S01831393. also how do we order a replacement manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
May 22, 2011 | Amana Refrigerators
I have an Amana model no. ARS2663AW refrigerator with a built in ice-maker. The ice-maker keeps freezing up. By that I mean the tube that brings the water down to the ice-maker tray seems to freeze. This...
Think of a water faucet.. You turn it on and water comes out and you turn it off and the water stops, right? Now when a faucet gets old sometimes it will drip and you have to jiggle it to make it stop.
In the back of the fridge you have the same basic thing. A valve that opens and closes to allow water to flow.. It is split into two sides, one for the water in the door and one for the icemaker.
One side could go bad while the other still works and that sounds like what is happening. Some have one and some have two depending on if you have a water filter but this one looks to be an oldie but goodie before the water filters were factory installed.
The part# you need is WPW10247599 and I fount it for under 40$. You need to unplug the unit and turn off the water to it. Change the valve and defrost the tube going to the icemaker.repair if needed.
whirlpool-invensys-service-replace-wpw10247599-ap6017730_04_l-5dtrzrhacenyq0nfrt1kdhhl-3-0.jpg
Jan 28, 2018 | Amana Refrigerators
How much space is needed between the refrigerator and cabinets, top and sides?
Down to zero on the sides ... 4 iches in the back ... couple inches at the top ... unless Amana tells yo something different in the owners manual ... http://www.amana.com/
Thanks for your visit today.
Feb 02, 2011 | Amana ASD2626HE Side by Side Refrigerator
We have a Amana refrigerator Model # SXD22SW2 and need to replace the water filter. We don't have the owner's/service manual for the refrigerator and I have looked everywhere on-line, including the Amana...
Removing a water filter from the base grill of your Amana brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Oct 13, 2010 | Amana SXD524VW Side by Side Refrigerator
Amana Fridge isn't filling the ice tray with water...=/
it seems to me (no expert) that you have an ice buildup in the tubing to the freezing portion of that unit. I can only suggest to turn off the Refrigerator for a little while, an hour or two at most, and see if the tubing thaws.
Aug 30, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Amana SR520SSide by side fridge freezer: How do I take off the dm
CLICK HERE for a PDF version of your use and care manual.
CLICK HERE for Installation Manual.
Page 3 of the installation Manual has the instructions on removing the doors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My refrigerator is freezing everyting
ur temprature knob is not adjusted so u have to read the manual ok.read it and adjust it
Apr 17, 2009 | Amana ARSE66MB Side by Side Refrigerator
Cubic feet?
Most refrigerator models with two digits, the rest letters, the digits stand for the cubic foot capacity of the refrigerator. In you case, 23 cubic foot model.
Sep 16, 2008 | Amana Refrigerators
Refrigerators Logo
64 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
