Question about Music
I own a Mackie CFX20. It isn't the MKII. The effects are very weak, and they buzz a little when you try to use them. How can I fix them, and is a service manual available?
    Genius:
  • 1,212 Answers
I would spend some time with contact cleaner, apply it to the switch contacts of any 1/4 inch jacks, and all of the connectors to the effects boards- it will entail some disassembly. Check all chassis ground connections you may have one that is a bit loose, broken, or corroded.
The Mackie support downloads for manuals has 2 sections- you needed to look at the top at the "discontinued products" Where these are.
http://www.mackie.com/support/downloads/discontinued.html
http://www.mackie.com/pdf/cfx_om.pdf
http://www.mackie.com/pdf/cfxseries_ss.pdf
http://www.mackie.com/pdf/cfxseries_hu.pdf
http://www.mackie.com/de/pdf/CFXSeries_OM_German.pdf
Posted on Feb 21, 2012
3 Suggested Answers
  • 5603 Answers
SOURCE: have a mackie cfx20 and i'm only geting signal on rightside
Make sure the PAN knobs are centered...
Also you can do a lot of troubleshooting with headphones in monitor jacks, etc.
Remember to use BALANCED lines out of the mixer which are either XLR or TRS type cables.
Posted on Apr 03, 2010
  • 5603 Answers
SOURCE: I need a chematic of graphic eq to mackie cfx20
Here is the complete service manual:
http://elektrotanya.com/mackie_cfx20_sm.pdf/download.html
Posted on Feb 04, 2011
I can't get sound
Please post some more detail of how each channel is set up and what you have assigned where. My guess is that reading the manual may sort your issues.
Jun 27, 2014 | Mackie cfx20 mkII compact mixer
Our mixture MACKIE CFX 20 give a humming sound as the clip light always on, but this does not happen before, tell me how to stop this
You say the clip light is always on, as the only clip lights on this mixer are on the effects channel and the master output and you do not say which is on there are a number of possibilities. You may have the effects turned up too far as this should not be showing, just maybe blinking, turn them down on efx2 on all strips as well as on the effects processor and see if this helps. If it does you may be able to find where the hum is coming from by gradually increasing each until you find it.
If you are getting the clip on the main mix master and you are not being deafened and the humming sound is coming from the speakers not the mixer you may have a subsonic signal getting into the mixer. Disconnect all inputs and if this cures it go through until you find where it is getting in and sort that.
If the humming is coming from the mixer it is possible that the smoothing caps on the PSU are dying, you do not say if you are getting normal sound as well as the humming from the mixer.
When asking for help please try to give as much information as possible
Sep 27, 2012 | Mackie cfx20 mkII compact mixer
Aux Channel 1 not working
What makes you say it works fine if you are getting no output? Have you just got it turned down?
May 21, 2012 | Mackie cfx20 mkII compact mixer
I have an opportunity to buy a cfx20 mixer from a guy for a really good price, but both the XLR and 1/4" jacks aren't working on one of the main outputs. I suspect it's the master slider, and...
If headphones have both sides working, it is NOT the main fader. It would most likey be the driver chip for the failed side that has been blown. This is common problem when people fail to power the mixer from the same receptacle or power conditioner that amps and other connected equipment are powered from. Ground bounce damages the circuits. The balanced outputs are driven by NJM4560 op amps which are likely surface mounted 8pin chips... .
Here is service manual:
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers.
Jul 12, 2011 | Mackie cfx20 mkII compact mixer
If I solo something, that level bleeds onto the Main. If everything is down, there is still some bleed over. Sub outs work fine, but then I lose the effects.
The channel solo does NOT kill the subs for the channel, so if you have the subs going to effects and back to the mains that path will still get to the mains appearing as bleed Here is the service manual for the CFX20 which is just more channels of yours.
Scroll down to "get manual" and click to download. Ignore other download links which are for viewers, etc..
Jul 02, 2011 | Mackie CFX 16 mkII 16 Ch. Compact SR Mixer...
Aux pots severely bent but not broken off.
Shafts will SURELY break if you try to straighten them. Replacing these requires labor of removing a lot of knobs and screws... cost of the pots is minimal.
Jun 21, 2011 | Mackie cfx20 mkII compact mixer
Would you know how to correctly open a CFX20 to clean the pots?
Yopu do NOT clean the pots... if you have noisy sliders, get some CRC226 at Home Depot in the electrical dept. Spray a small bit in the center of the slot for the slider and run the slider up and down. Use sparingly and apply a tiny amount once more. The sliders are NON_REPAIRABLE if this won't fix them and major disassembly is required involving removing the round knobs, fader knobs, screws and other nuts on the jacks. Hours of work. Pots require desoldering tool and use of soloder wick and plunger type removal tools often causes damage to the circuit board.
May 27, 2011 | Mackie cfx20 mkII compact mixer
Have a mackie cfx20 and i'm only geting signal on rightside
Apr 03, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Music Logo
156 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
