Question about JVC AV-32950 TV
No power and won't turn on
The TV will will not turn on with either the remote or front panel. AC power is getting to the power supply and I checked the fuse. The fuse is good. I'm not sure where or what to check on the power supply for proper operation. Is it cheaper to get a whole new main board or fix the individual component?
  • mrstyl Jul 31, 2008
    I just had the same problem. When I cracked open the backside and
    looked on the panel where the volume, channel, menu, and power on
    buttons are, I noticed that the power button was disconnected from the
    board. It was just a matter of soldering it back to the board and it
    powered up fine from that point on.
  • 3,130 Answers
If you know how to use the multimeter is to get a service manual. Try Then troubleshoot the power supply and the sweep supplys. In most cases if you had to replace a complete board,unless you get it from an exchange company that repairs boards such as, then it exceeds the cost of a new set. Good Luck
Posted on Aug 26, 2006
  • Larry  Dillon
    Larry Dillon Aug 26, 2006
    opps I added a comma to the pts addy It should read
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
Tv won't turn on
Chech whether AC power get into the power supply regulator section. Just open your tV, and check it. There is a fuse [ glass cartridge type] on the power supply section. Check whether it has blown up or not. If blown up, make sure that there is some shorted components at the power supply section check it.
Feb 27, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
The tv wont power on at all
Your TV Won't Turn On
If your TV won't turn on, you should check the power cord. Make sure that it is securely in the wall plug. Sometimes the power cord has burned out and needs to be replaced. You may also want to check the batteries in the remote to make sure that they are working properly. If otherwise
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, if otherwise, Power supply board just die.It can be dead at anytime.Tries websites, to buy a refurbish power supply board for the replacement.
I hope this will help to solve the problem.....
Jul 07, 2011 | HP Pavilion MD5020N 50" DLP HDTV
My vizio e420vl turned itself off and won't turn back on. When i plug it in the vizio logo lights up amber but it won't do anything else.
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
May 29, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
Could the front contol panel be bad if my T.V. dont turn on
More likely no power to set; either no AC from plug outlet, or internal fuse in power supply.
Apr 19, 2010 | Mitsubishi VS-45607 45" Rear Projection...
I have a daewoo pdh42L40 monitor and it does not turn on. The main power switch in the back works, but the little green light on the front does not light up so I can use my remote to turn on.
1. the infrared receiver may be defective and may need replacement.
This will require service from a qualified tech to replace.
2. or you may have a dead remote. check the batteries also in the remote.
Jan 23, 2010 | Daewoo DSL-17DW3 17.1 in. HD-Ready LCD...
JVC AV-32950 TV Logo
102 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
