Question about General Electric Dryers
Amana Electric Dryer
Dryer is getting power because the lights come on. The 'start/pause' button blinks after pushing the 'power' button, but nothing happens. The drum doesn't turn, no heat, nothing. Vacuumed the lint trap, checked the connections and hoses in the back for compression, blockages. Again, nothing. Desperate!
    Scholar:
  • 177 Answers
You lucked out there but better replace that start switch because it will do it again just when you don't want it tol
Posted on Jun 17, 2014
Illeagle
  • 525 Answers
SOURCE: Amana dryer
Check your fuses or breaker. An electric dryer requires 240 volts to operate. In a fuse box system, 2-30 amp fuses are required for an electric dryer to operate. If 1 fuse is blown it will not start or heat depending on which fuse is blown.
In a breaker system the breaker can trip and sometimes look ok. Find your 30 amp dryer breaker and reset it by flipping the lever to off, then back on.
If this doesn't help, you may have a faulty door switch or maybe your door has loosened from the hinges and has sagged a bit, breaking contact with the door switch plunger.
If you can locate the door switch, push on the plunger... you should hear an audible click...if you do then the door switch is normally ok, but not always, it is just a simple test to rule a bad switch which is normally silent if it is faulty.
You may want to inspect for a burned wire or wire termination.
Make sure dryer is unplugged from the power source before inspecting!!!
Other than the previous instructions, it is difficult for a novice to diagnose the problem...call a technician in to fix your dryer.
1 more thing, Just because a breaker appears to be on, and/or you flipped it off then on, doesn't mean the breaker is ok. Fuses also can look good and be bad. A small volt-ohm meter($10.00) is a good investment for testing voltage, and to save time and money.
Hope this gets you up and running.
Posted on May 26, 2008
SOURCE: Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Posted on Jan 03, 2009
  • 686 Answers
SOURCE: frigidaire dryer stuck in cool down mode
post model number
Posted on Apr 05, 2009
  • 77 Answers
SOURCE: lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Posted on Apr 20, 2009
  • 10 Answers
SOURCE: Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
Posted on May 12, 2009
I have and Amana electric dryer when I push the start button it buzzes and does not start
Wild guess the dryer is overloaded, Or too hot and needs to cool down. There are temp sensors that will prevent starting when too hot. You may have drive belt or fan problems exhaust pipe clog.
Feb 28, 2015 | Amana DLE330RAW Electric Dryer
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Stop button doesn't work on Amana NED7200TW Electric Dryer.
Check the door switch to see if it "clicks" when you push and release it. If it clicks, then the control board will need to be replaced. Here is the part you will need to order.
Nov 01, 2012 | Dryers
JUST MOVED TO A NEW LOCATION AND THE BRAVOS DRYER WONT WORK.POWER BUTTON WILL NOT POWER DOWN AND PAUSE START BUTTON WILL DO NOTHING.
Double check the power source, you may need to reset the breaker. It would be rare that the dryer would fault internally during transit because a gas ignitor you be the loss and you do not have one. Check the power supply and confirm you have at least 220 volt to wall and dryer. Get back to me if you need more help.
Thanks
Nov 20, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer will not start
It is very likely that the dryers heating element is burned out, that would be the 1st thing I'd test.
Nov 19, 2011 | Amana NED7200TW Electric Dryer
I'VE HAD MY DRYER 3 YEARS. POWER COMES ON BUT WHEN YOU PUSH START BUTTON THERE'S JUST A PAUSE AND THE ERROR CODE " F". PLEASE HELP!!
Select any one button (except POWER, START, and STOP) and follow
the steps below, using the same button (remember the button):
Press/hold
3 seconds
➔ Release for
3 seconds
➔ Press/hold
3 seconds
➔Release for
3 seconds
➔ Press/hold
3 seconds
All indicators on the console will
momentarily turn off, then turn back on with 88 displayed. After
5 seconds, the Automatic test begins.
Use the tech sheet info on page 2 as a starting point
Note to get the exact tech sheet or manual for your machine go to ServiceMatters and post your model number.
May 03, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dryer won't start
try stop clear pad if that doesnt do it try unplugging the drier then plugging it back up is it giving you any f codes at all etc f1 f2 how old is the drier and how did you check the power at the outlet let me know
Dec 31, 2007 | Frigidaire FEQ1442ES Electric Dryer
Dryer does not turn on
Sounds like the motor relay is not functioning. Sometimes the motor will work if the button is pushed but will stop when the button is released. This is caused by a loose wire at the motor or a bad motor relay.
Oct 18, 2007 | Amana DLE330RAW Electric Dryer
Dryers Logo
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
